As above, I have my old setup consisting of four pot Sumitomo Z32 calipers with Ford Mustang 287mm vented slotted discs mounted on 260Z hubs ready to bolt on to either a 240 or 260Z. Can fit at least 15" wheels (depending on offset). Setup is around 2 years old an only done a handful of sprints. Work very well and have plenty of life left in them.
Asking $650.
Pm or call / SMS O413 243 76O Can help with fitting if needed. Would be good to get some braided lines made up to go from the original zed fitting to the caliper as they are different.
Pic shown was when they were new; now just a tad rustier and a bit used but still don't look any different.
Dimitri, do you know if Z32 calipers are the same as R33GTS-T calipers?
They are different from memory.. I think bolt spacing has been altered. My calipers have been modified to bolt on to a zed strut without having to modify the strut itself.
Pics will be posted later today.
Z32 calipers are the same as R33 GTST/R32 GTR calipers, that is if they are the ribbed casting like I assume yours are Dimitri?
From memory the R32 are different to the R33. R32 and Z32 calipers are identical but all R33 are the smooth body with a different bolt spacing.
I am using a 15/16 MC as I was running with R31 rear setup which is still on the car. I'm sure these will work just as well with a standard MC.
I do have a 15/16 MC that I can sell separately if needed.
Did a bit of a price cut before I try my luck on evilBay. Anyone want awesome breaks (sic) for your Zed?
On ebay at the moment, but if anyone on the forum want them, if you have a good offer, they can be yours!! If you've entered the Nationals and running at the Island, heres a chance to get some awesome brakes before the event...... Don't miss out!
