  1. Yesterday
  2. NickF
    door alignment
  3. Last week
  4. i think i saw some 'group buys' on the forum in the past would people want any of the panels to share freight
  5. saw that. appears to be 300%+ ,markup over the factory price. must be the shipping
  6. C.A.R.
    door alignment
  7. If you want china panels, you can get them here in Australia: https://allmusclecarparts.com.au/datsun/240-260z.html Do they fit? Yes. Are they OEM quality? No.
  8. Stuff has started appearing on Aliexpress. Has anyone bought any of them and does it fit?
  9. NickF
    door alignment
  10. Measure the thickness of the original panel, then replicate in the appropriate thickness steel. 0.7mm & 0.95mm cold-rolled are both available from steel merchants.
  11. Back from a break so back on this topic Need to make a couple of patch panels , presumably 1 mm and 1.2 are the way to go? When I measured up some of the parts, they seemed to be only0.7 to 0.8 though Presumably these are the standard sizes in Oz Cold Rolled Steel Sheet - Melsteel
  12. Did you sort the dimensions? are the plans incorrect?
  13. BOT alert. Gavin or admin please have a look.
  14. https://GirlSingle.com Find a girl who shares your desires [url=https://GirlSingle.com] Real Girls. Real Nights. [/url]
  15. Earlier
  16. It's on again! Date: Sunday 29th November 2026 Time: 11am Onwards. Location: Same as previous years, Gordon and Sharon's property in the outer East near Lilydale. Please prey for dry weather! PM me or @Gordo for the address if you haven't been before. Bring your Zed, food and Drink and a chair. The wood fired BBQ will be provided. Bring your Wives , partners and kids. All welcome!
  17. Just media blast it or soak it in a 4:1 Water & Critic Acid solution.
  18. Experiments in dealing with rust coming up. Chemical rust removal, chemical rust conversion (iron phosphate and zinc phosphate) and mechanical removal. Start with small less rusted parts. Any tips appreciated! Supplies and advice came from Milsome's Auto paints in Ferntree Gully, they seemed very good.
  19. Will add this one to my list: https://bringatrailer.com/listing/1967-datsun-411-sss-wagon/
  20. AI can be hit and miss. I asked AI the length of the Z car bonnet, it said 2.4m. Ah, that’s the car length. Now it says 1.6m. I think it’s closer to 1.4. I’d assume you have some packages of hardware bolts, just try some and see what it is. Or take the handle to Bunnings and find some loose bolts to test. Actually, on mine, it looked like a pin was used, so AI is wrong again about it being a screw. Some probably are, but not all, I suspect.
  21. not m4 as it says here? What’s the thread pitch?
  22. Yeah neither of my shifters has them. I’d buy new anyway if I was you….
  23. Thanks! Despite people saying the bumper mounts were too high, the pics of rotisseries did suggest they were actually too low!
  24. Convert it to manual transmission, and you wont have to worry about the screws (you can buy them from your local bolt shop - M6 counter sunk)
  25. Centre of balance point is 75mm above the bumper centre-line. It's very easy to work out. The F&R bumper mounts are plenty strong enough to support a bare Z shell. FWIW we have two rotisseries that we made from engines stands with the centre mast raised by 400mm. Don't over think it - they are easy to build.
  26. Hi, looking for a rotisserie, ideally 2nd hand (in Melb / Vic), but also tempted to build. Some people have used two engine stands, but they're too low so need modifying. They do need to be connected together. Trick will be getting the correct pivot height, so its easy to turn and will stay in any angle without excessive locking. Two people have both said the bumper mounts are too high and the car is bottom heavy. But if that changes between US and AUS, or 240-260-280 I'm not sure. Commercial items: This one is said to rotate very easily: was sold on this forum a few years ago (Peter Allen) DIY: DIY with adjustable point of rotation: This person used two vertical pipes that are on each end are held by u-bolts through the engine stand. So the car can be raised or lowered to get it to the proper balance point. (car is sideways in the pic) They say "the car is very neutral and can easily be spun with one hand. You can use the pin on the engine stand to hold the car in any orientation. When I go to set it down on it's wheels, I can loosen the u-bolts and slide it down until it is close to the ground". So, anyone have one for sale? Or any experience building one? I like the idea of one that can be adjusted to find the C of G. Cheers, Richard
  27. I'll have a look tomorrow (aren't at the location of my car until then). I know I have two auto shifters, and I going to convert to a manual. But you know what they look like.. A nut and bolt store might be the go. Mine could be quite rusty..
  28. Surely someone who has done a manual conversion has these!? If anyone has these screws, please message me! Sth East Melbourne location.
