  1. Yesterday
  2. 45mm Steel Hub Dust Cap Zinc Plated - 2PC - Superior Trailer Parts 45mm outer, same as z front hub bearing caps..... massive price difference from original and ill be powder coating these black .... not sure if anyone has tried this before?
  3. Last week
  4. Earlier
  5. Refer to the donk in the engine bar: and maybe the flares too haha
  6. I need the following items, does anybody have these or know where to buy without freight costing $100 for an envelope!
  7. https://www.carsales.com.au/cars/details/1969-datsun-1600-manual/OAG-AD-24642820/ or here https://autodynasty.com.au/buy/1969-nissan-bluebird-/Q2QGzaynhcol8AVATQrdqA Another ripper!
  8. Would be interesting to start a discussion thread mods you wish previous owners HADN'T made!
  9. Go to this youtube video: Go to approx. 1.0 minutes. This is LHD VIN#16 which was one of the first cars sold to the general public in the USA. The car was originally gold and was repainted white in the early 1970's. The stickers/decals were applied to the time of the repaint. Its 1970's cool.
  10. I love originality, but for me... Upgraded Brakes Fuel injection and modern ECU Air Con (for hot summer days in Australia) Upgraded wiper and heater / fan motor. Makes the car infinitely more usable all year around.
  11. Another local option is Coilovers by Supafatto. You can find him on Facebook or below. https://www.pitloon.com/businesses/supafatto
  12. $3k-$4k buy the time it's all done. We are in the Latrobe Valley.
  13. What’s the cost to do this as I’ll probably end up going this way too? Where are you located?
  14. I'm currently working on Daniels suspension for his restoration. The struts are away getting their tubes shortened so we can obtain enough bump travel. Then to get the ride height lower still with the Lovells lowering springs, I'm going to drop the perches on the tubes until I get the ride height I'm after. I ended up using Koni Yellow Sport damper inserts from the front of a Z31 for all for corners, with a special Koni gland nut to suit the 55mm strut tubes. In the future if Daniel wants firmer springs or the ability to easily adjust the ride height, he can fit height adjustable platforms.
  15. Always been a huge fan of pin striping on vehicles and would love to see if any members have gone down the route of putting stripes on their z's and would love to see some pictures..... The more 70's retro the stripes, the better. GO!
  16. what did you end up going with and any pics showing ride height?
  17. (Ok, not sure why it won’t let me add my text..) Possibly how long is a piece of string, but can I ask here what would be a typical price for that process, assuming the car is “roll in” ready? Though it will be years before we are in that situation. Cheers….
  18. I went with some products from Car Builders : 1) Insul-Layer - applied to inside of doors and rear quarter panels 2) Mass Noise Liner - used in place of the old sisal under carpet areas and on the firewall. From their web site : "Sound deadener is generally a misunderstood material. Normally the first stage of treating noise is referred to as ‘sound deadener’. This stage only really treats vibration in panels. It was often a bitumen-based product but more commonly consists of a butyl rubber with an aluminium top layer. Cheaper sound dampening sheets consist of a lower grade butyl, which is not as durable or resistant as those used by leading brands. Butyl sheets by themselves however, will not result in dampening droning or external noise that you may be more interested in treating. This will be treated more successfully with mass loaded vinyls. If you are aware of the type of sounds that are annoying, you will be able to treat them more successfully with targeted products."
  19. In our shop, from bare metal we Epoxy, then prime, then mask off the rails, stone chip the flat panels, then apply body colour over everything. IMHO This is the most professional way to go about the underside of a Z:
  20. Thanks very much! The engine in an L26, but not matching number. It’s been “rebuilt” and I think doesn’t involve any modifications. So it’s a completely standard L26. I intend to run extractors, not the standard exhaust, but at this stage have no modifications planned for the engine itself, and the only mods are the intake, webbers, and exhaust. But a different cam shaft might make those modifications a lot more beneficial, so perhaps we’ll change the cam. I’m pretty comfortable doing engine and mechanical work. I did read some threads here on webbers, and the debate of 40 vs 45s. I’m inclined towards the 45s. But it will be a few years before the engine gets installed. Also curious what people think is the best surface treatment for the cars underside when repainted. Some chassis you see painted on the bottom identical to everywhere else. Others have some sort of black coating, perhaps sound deadening, or rust prevention? Keen to make sure the car has good noise, vibration, and handling qualities, because those aspects give a car a feeling of value.
  21. If you go this way make sure you get the 45 DCOE 152G Weber Carburettor that has the 4 progression holes. You will need to specify what engine specs you have as it will influence what chokes, idle jets, emulsion tubes, and main jets are required in the Webers- best to get advice on this as it becomes expensive to replace all of these.
  22. - If you have to rebuild the L26, look at rebuilding an L28 instead. Depending on your budget for the motor, you can get a decent build out of Pearl Automotive Engineering (VIC). - Buy brand new Triple Webers from Weber Performance (VIC), and go straight for 45s. Even if you put the L26 in, and an L28 is an option later on, atleast you will have 45s already.
  23. Thanks! Some very useful tips there. The Subaru AC is my own idea. The daily is an outback and I like the system in it. I think it might be feasible to install into a Z. The think the hardest parts would be fabricating brackets, mounting, ducts under the dash, and if the heater core, AC core, blower would fit even with those adaptions. Then, wiring for the control module. It would be really nice to have a thermostat controlled heater / AC, with electronic controls not cables on sliders. Looking at generic aftermarket units, they’re not designed for a Z either, judging by comments in this forum. Why pay $3k for new parts for a system that doesn’t fit, when I can get all the bits secondhand from a wrecker for likely a lot less, that maybe doesn’t fit any worse? We shall experiment and explore…. Cheers!
  24. My painter has now requested that we make the 260Z at least a rolling shell or drivable, so it's easy to move into paint booth. So I had a chat with Daniel about the direction of the build, as I was not going to refit the dirty and rusty suspension to the freshly painted chassis. We came to the decision to break the suspension down, have it media blasted and painted in 2k black. ALL the fasteners, brackets, catch's etc were cleaned and wire wheeled, then sent off for electroplating. The braking system can be upgraded later on by Daniel if he so wishes, but for the moment we had all the braking components rebuilt. However Daniel DID want a suitably lowered ride height, so I purchased a set of Z31 Front Koni Yellows, and Lovells 30mm lowered rear springs. The old Pedders 'Comfort Gas' inserts went in the bin! A new rubber suspension bush kit will be installed. Daniel had SW Motorsport rebuild the engine, with some tasty mods. Stewart then shipped it down to us to install. More on this later.
  25. Time for another update! My painter was busy (he always is) but eventually he made progress, an in the space of a couple of weeks, it was in high build primer and the underbody in Nissan 305 LMB!
  26. 5 speed manual box (don't know what options exist) 280ZX / S2 bluebird '71B' is a bolt in. You can fit a 71C box from an S13 or R31/2 Skyline, but it requires mods and is not DIY friendly. You will also need to consider your diff ratio, as the auto diff is very tall. Subaru A/C system I've not heard of this. Another option is an AC system from a later 260Z is a bolt in, or you could go Vintage Air. Possibly a body kit (flares, side skirts, air dam, haven't seen a spoiler I like yet.) Each to their own, but none of the bodykits of seen for a Z improve the looks. Possible after market front suspension to eliminate rumor of bump steer. It's not a rumor and it gets worse the more you lower a Z. And it's a significant undertaking to deal with it, and none of the adjustable suspension kits on the market adequately deals with the issue. I suggest you speak to a Zed specialist - either Les Collins or Stewart Wilkins.
  27. https://www.carsales.com.au/cars/details/1972-datsun-1600-gl-auto/SSE-AD-20635439/ What a ripper!
