https://www.facebook.com/marketplace/item/895800226103235/?ref=search&referral_code=null&referral_story_type=post Might be worth finding out the chassis number for the database -
https://bringatrailer.com/listing/1970-datsun-240z-147/ HS30 99 The seller is Jon Newlyn who also owns MBP72J which was one of the first (if not the first) car in the UK, the VIN slips my mind at the moment. -
Harekori joined the community
I would love to know peoples thoughts on running old school Centrelines on these cars. I have always been a fan of the 70's muscle looking wheels and not sure if its just so outdated to do these days or if its considered cool. I wouldn't want to roll around getting laughed at albeit thinking im "cool" Having said that, I need to move my factory wheels on so I can afford something new. Shit thing is I just restored/powdercoated these last year and paid $780 for the work as the black parts are painted and rest is powder coated and was a bit tricky to do ..... rear set is 215 and fronts are 195, brand new tyres. Which i also spent $700 on!! Car has been sitting on them in my garage as its still just a rolling project. What can I sell them for and is anyone interested? Sth east Melbourne pick up.
START DIGGIN! I NEED IT hahah
I know I have one from an Aus delivered 260z I just need to find it
yeah i always wondered about people buying those in the US as I am assuming the indicator and headlight switch is the other way round anyhow....
Just be wary of any ones you find on eBay as it appears the USA ones are quite different to those on the Aus delivered cars and most of those shown say "Untested" so will have faults.
RichyRich replied to gav240z's topic in Cars For Sale
1974 260Z tarmac rally car RS30-001049 $38k https://www.my105.com/search/details/1974-datsun-260z-rally-car/15d332ff-519c-436f-b61e-a767b37040cf?source=SEARCH_RESULT 1971 240z Rolling shell build no 1561, $11k, sold (nice dash!!) https://www.my105.com/search/details/1971-datsun-240z-s30-shell/97cffddb-cb34-4fd1-8c8e-104eb276994f?source=SEARCH_RESULT 1973 240z $59.9k https://www.facebook.com/marketplace/item/802898422754548/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A545b2a98-9789-4092-a11e-38d4a71aed48 -
PHATSUN changed their profile photo
Joe you kept my motivation going, thanks. Update: I set the "Fun" level to 10. I bought a flaring tool. From EFI Solutions I bought: steel 3/16 brake line and stainless brake tube nuts (M10x1.0mm) so an ape like me can't strip them again. I've had a crack at double flares and finally got them tight enough to sit nicely against the nuts - I guess until I pressurise them I won't know if I did a good or a bad job. It's not like I'd have to undo the whole thing if they were bad....oh... The brake juice had stripped all the paint off my rails so whilst I had parts removed and some access...first attempt at rust converter last night, it's a mess. Then some primer later today straight over it. What could POSSIBLY go wrong? (/sarcasm) Anyone feel free to correct me if I am off course. Next: primer, then rattle can of VGPaint 306, then tape it all up ready for more leaks, then bend the brake lines into shape, test fit, redo it x10, then bleed brakes. -
Hoody joined the community
Sorry for my dribs and drabs posts on this one. If you dont have a flare nut spanner already get the best quality one that you are able to budget for as the cheaper ones tend to open up a little as you are using them. If you need to know the size please let me know I dont know it off the top of my head anymore as I havent "spannered" for a while but Im happy to check my toolbox over the weekend if you need the correct size.
