Jk_zeder
Everything posted by Jk_zeder
  1. OMP Widebody Seat (Only a year old) - $350 OMP 3” 4point harness (only a year old) - $200 Saas Bucket Seat - $100 2” OMP Harness for passengers - $100 Only have the above left, Diff is sold pending payment.
  2. Only things that are left are the following - R180 locked diff with 4.8 diff gears (fresh) - $400 OMP Widebody Seat (Only a year old) - $450 OMP 3” 4point harness (only a year old) - $200 Saas Bucket Seat - $100 2” OMP Harness for passengers - $100 Rota RBX 9.5 rears/9.0 fronts -19/-13 offsets on Fed RSR Semi’s - $1000 240Z Dash, great condition except for where a hole was drilled in for a shift light, please see the pics. Gauges are included. - $400 Need this stuff out of the shed!
  3. Id sell my full rebuilt rb20det box ready to bolted up for $1500 if you change your mind
  4. Open to offers, just throw me a PM or sms. James
  5. List updated as of today
  6. I'll try and PM you a price today for shipping, I doubt it'll be cheap though
  7. Updated as of today
  8. Tail lights are gone I'm afraid. James
  9. Need all this stuff cleared out, open to offers and happy tomwork with you for postage etc
  10. Hey, they are from techno toy tuning and were put together by a professional, pretty they were tig welded because its so neat. They came withbthe perch and are 55mm iirc
  11. Hi all, As seen in the other topic HERE I'll be parting out the car instead after getting lots of interest for parts. Everything bar the engine was brought brand new for the car and at most parts have maybe 300ks of use. I'd like pick-up or delivery can be organised for South-East QLD by myself. The smaller Items I could post at your expense but the larger items for now you'd have to organise but im happy to help on my end. PMs are preferred or you can call/sms me on zero4seveneight118718 PICS FOUND HERE Engine – $4500 incl all below SOLD Approx 6500ks as it did a drive to Tassy for Targa and back to the coast before I purchased it from a mate. Made 170rwhp and 370nm of torque. Tuned by Gavin Wood. Dyno sheet available for viewing. Hot tanked P54 Block Bored 40 Thou. New flat top pistons & rings N42 Cyl Head – Crack tested and machined, light head work New bearings – Big End and Mains Fully balanced New Camshaft Nissan 812C 495 thou lift New Rocker Gear & Lash Pads New High Volume Oil Pump New Timing Chain and Sprockets New Adjustable Timing Gear SW Motorsport Harmonic Balancer New Electric Water Pump (CSR) Fully Modified Fuel Injected Inlet Manifold New Alloy Fuel Rail and Pressure Gauge Enlarged Throttle Body New Nissan R32 Injectors Fully Balanced and Lightened Flywheel Competition Velvet Touch Button Clutch & Pressure Plate Extractors 2.5" exhaust MSD Master Blaster Coil/Fully Modified Electronic Distributor MSD 6-AL Modified and Baffled Sump Alloy Radiator with twin thermos 2L Surge Tank mounted in the engine bay EF Falcon pick-up pump Bosch 044 fuel pump VL Turbo Starter Motor Oil Cooler incl plate etc Turbosmart FPR (800 series) Driveline – RB20DET 5-speed with 71b bellhousing to bolt straight up(fresh 0ks, just had rebuild, have receipts, comes with mounts to bolt it straight in and gearstick) $2000 R180 locked diff with 4.8 diff gears - $500 280ZX Tailshaft, will need to be cut down for the setup - $100 Suspension & Brakes – Coilovers including hubs, bearings were all done at the same time. Brake brackets not included - $1800 SOLD Ground Control Weld-On Coilover Setup Eibach Springs (330lb Fronts 300lb Rears) Tokico Illumina 5-way adjustable shocks Techno Toy Front and Rear Lower Control Arms SOLD Techno Toy Tension Control Rods SOLD AZC Wilwood 4 pots all round (includes everything you get in the kit) - $1750 SOLD Interior – Racepak Digital Dash to Wolf V500 ECU (have to sell this as a package as the cable to talk to the dash only works with this ECU) $2000 SOLD OMP Detachable Steering wheel including boss kit - $320 OMP Widebody Seat (Only a year old) - $650 OMP 3” 4point harness (only a year old) - $300 Saas Bucket Seat - $120 2” OMP Harness for passengers - $100 Full switch panels for everything - $100 240Z Dash, great condition except for where a hole was drilled in for a shift light, please see the pics. Gauges are included. - $550 Front Strut Bar - SOLD Rear Strut Bar - SOLD Exterior - 240 Shell with flares - $4500 Rota RBX 9.5 rears/9.0 fronts -19/-13 offsets on Fed RSR Semi’s - $1250 Alloy Rear Spoiler - $100 Modified Baffled Fuel Tank - SOLD Thanks guys, James.
  12. Lots of interest coming through so please bare with me I'll get back to you asap. James
  13. Considering parting this out. If there is something specific you are interested in, sending me an EOI. James
  14. Not a bad idea Jason, he could throw the efi in the roady
  15. Very open to offers.
  16. Would like to get this out of the shed, hit me up for more details and get some offers coming my way
  17. Thanks for the posts as well Matt and Richard.
  18. Anything is possible but it really would take some effort and dollars. The car was gutted out as much as possible for track. Cars kerb weight with fuel etc is at 940kg.
  19. No cage, was next to happen. Never got to a CAMS event
  20. Its completely gutted mate, getting it back in the road would be a mission.
  21. NOW PARTING OUT SEE HERE For some of the build and Pics go here - http://www.viczcar.com/forum/index.php/topic,9086.0.html This car has only been out a total of 3 times . It managed a 64 in a large pack at Lakeside (first time every out) A 64 at QR on Clubman, first time on the track. Also managed a 63 second lap at Norwell, enough to beat 57 other cars. Engine – Approx 6500ks as it did a drive to Tassy for Targa and back to the coast before I purchased it from a mate. Made 170rwhp and 370nm of torque. Tuned by Gavin Wood. Hot tanked P54 Block Bored 40 Thou. New flat top pistons & rings N42 Cyl Head – Crack tested and machined New bearings – Big End and Mains Fully balanced New Camshaft Nissan 812C 495 thou lift New Rocker Gear & Lash Pads New High Volume Oil Pump New Timing Chain and Sprockets New Adjustable Timing Gear SW Motorsport Harmonic Balancer New Electric Water Pump (CSR) Fully Modified Fuel Injected Inlet Manifold New Alloy Fuel Rail and Pressure Gauge Enlarged Throttle Body New Nissan R32 Injectors Fully Balanced and Lightened Flywheel Competition Velvet Touch Button Clutch & Pressure Plate Extractors MSD Master Blaster Coil/Fully Modified Electronic Distributor MSD 6-AL V500 Wolf Computer Modified and Baffled Sump Alloy Radiator with twin thermos 2L Surge Tank mounted in the engine bay EF Falcon pick-up pump Bosch 044 fuel pump Light weight race battery VL Turbo Starter Motor Driveline – RB20DET 5-speed (fresh 0ks, just had rebuilt have receipts) R180 locked diff with 4.8 diff gears New tail shaft – being done this week Suspension & Brakes – Techno Toy Front and Rear Lower Control Arms Techno Toy Tension Control Rods Ground Control Weld-On Coilover Setup Eibach Springs (330lb Fronts 300lb Rears) Tokico Illumina 5-way adjustable shocks AZC Wilwood 4 pots all round Rota RBX 9.5 rears/9.0 fronts -19/-13 offsets on Fed RSR Semi’s Interior – Racepak Digital Dash running off the ECU OMP Detachable Steering wheel OMP Widebody Seat (Only a year old) OMP 3” 4point harness (only a year old) Saas Bucket Seat & 2” OMP Harness for passengers Full switch panels for everything I’ve tried to include as much as possible, this car has had a lot of hours put into it, every single bolt and screw has been replaced for new. There’s been a lot of little modifications in which I am happy to go over with serious buyers, a lot of the guys up here fed us with a lot of very useful info so we were able to skip a lot of R&D and get a competitive car on the track. I just do not have the time for the car anymore and wish to get back into a better street car. I am interested in swaps+ cash or clean swaps or the car +cash your way for anything of interest, show me what you have, don’t be shy! PRICE: $16,500 Car is located on the Gold Coast. Please PM me or SMS me on zero4seveneight118718, I work a lot of hours so cannot accept calls a lot of the time. Going to be sad to see it go but it's worse to let it sit in the garage, I'd rather someone enjoy it. Cheers fellas, James
  22. One thing I didnt mention is that I have the rb20 turbo box rebuilt. Still has 0 Ks on it.
  23. for a trade/swap Id like to see 25ish maybe. With full understanding of 'you dont get money back on race cars' it's a fresh build and a push button and go setup Keen for a nice daily again or any other toys people may have. Don't be scared Im open to a lot at the moment.
  24. Considering swaps/trades/sale for the 240.. Car just needs a driveshaft, which Id get done for the new owner. Time with work forfeits all ability to race and Id rather see this thing getting driven then sit in a shed. You can PM me for now. Im not going to put a price on it yet, will see what people come up with.
