Hi all,
So, 20 years ago I put a used (repaired) heater core into my 1971 240Z as part of the restoration. Works done by a store in Mordialloc, did a great job on the core and an uprated radiator.
However, after driving this weekend, I noticed that there was some coolant leaking inside. I assumed non-standard heater tap had gone again. However, when I had a closer look tunnel was damp and seemed to be a larger leak from the core itself (explain the drop in coolant).
Anyway, I don't have time/energy to do the heater core work (2xkids and own business), wonder if anyone has a shop suggestion around SE suburbs? (we are in Hawthorn but I have a shop in Moorabin in mind).
Will be:
- fault diagnosis (although I have a strong suspicion);
- fix; and
- hopefully, new cooling system cables all round (had been meaning to buy from US but a shop should be able to make easily) - heater system has always been NQR (I built it...which explain a lot).
Have to do it before I can move on to the fun stuff of getting the interior really right...
Huw
