So! The kit is installed and i can give you all some feedback on how it turned out (followed at some point with pictures)
Trans tunnel: perfect to a fault, turns out on left hand drive cars the handbrake is still located on the right hand side of the centre console aaaaaaaand in doing so is located a lot further forward than where it sits on a right hand drive car. This led to the cutout for the handbrake to be a good 30cm too far forward. To get around this I made a template of the hole and cut it out where the handbrake was actually located and then used some excess trim offcuts to fill in the original hole. between the hole being located so far forward and lineing the excess trim up with the surrounding pattern it gets hidden nicely.
I applied this trim over sound deadner but even with the extra layer it fit quite well, a few relief cuts required and if you wanted a completely smooth appearance over the tunnel you will need to apply either extra deadner or some other material around the inconsistencies stamped into the metal.
luggage raiser: easiest to fit, no cutting required, however make sure to do this last as the side edges and hemmed seam over the centre console will present better than the other pieces.
strut tower and wheel arches: start at the back and then work towards the front of the car with these, some small cuts required around the luggage raiser. Found it hard to get these to stay tight as the carboard pieces that sit against the strut towers kept moving slightly. all up they don't look perfect but i'm more or less happy.
overall quality: pretty good (8/10) you will need to put in relief cuts and more than likely modify the trans tunnel piece but the materiel itself is really nice and workable. i went for the vinyl option over the genuine leather and couldn't be happier. Looks almost identical to the original 240z trim.
