hey,
i took the tapet cover off a 260z 2+2 with a l28 block and noticed the cam said 'e30' and 'japan' written on it.
i cant seem to find any info on it?!?
does anyone know what it is??
if its any help, it has n42 head and block...
thanks
E30 is just a casting code it means nothing.
As above, at rear of cam, you may need a mirror and a torch, will be the stock grind designation, usually A B or C.
Not much difference between these either.
