Hey guys wondering if anyone knows what model/part number/year  brake caliper rebuild kit i need to suit my non vented s12+8 Hilux front calipers and R31 skyline calipers.
Have seen a heap of rubber rebuild kits on ebay but unsure which exactly i need as i am not sure what model or year these calipers came from and have heard there are several types dependant on model.
Calipers are -Toyota Hilux 4 runner s12+8 calipers
                      -Nissan Skyline r31 silouette rear calipers.
Thanks
If you don't want to rebuild the r31 calipers yourself try better brakes mitcham as I took my old ones in there from the wreckers and did a changover for some rebuilt ones on the shelf, forget the actual cost but from memory i was very happy with the price.
There are 2 types of rebuild kits for the Hilux.  One for the one with pistons the same size and one for the odd sized pistons.
I recommend you ask Ash at morrabbin auto spares to get you the R31 kits also.  I spent quite some time trying to chase them done and he got them for me in a couple of days.
None of the ebay kits come with the 4 seals inbetween the calipers which imho would never need to be changed. Failing that you can use the seals for the inbetween bits from your old calipers (i did this). As Simon Said just make sure you get the right set and it's alllll Money!
Thanks guys. So far Alex (Agno) has offered to give me a spare kit he has for the Hilux calipers. So i will definately hit up Ash for the r31 seals.
Thanks again guys appreciate the help.  :D
Tai
Thanks for the plug sushi :)
Let me know if you still need the kits.
We can supply just the kits or can do the rebuild. We can also get the pistons for the hills calipers if yours are pitted.
Ash
