Gyra Posted October 9, 2012 Posted October 9, 2012 I've been experiencing poor handling and steering response on my car for some time now, but haven't had any spare time to investigate properly. Tonight I noticed the washers on the caster rods are installed differently. The right side has them cupped inwards, whereas the left has them cupped out wards. I'm guessing this is affecting both the caster and toe-in on one wheel. Probably my fault - don't know when... Any ideas which way is correct? Also the right hand rod seems to be adjustable, with a threaded section, where the left side doesn't have this. Is this a standard feature? Why not both? Thanks in advance! Gary Quote
Linton Posted October 9, 2012 Posted October 9, 2012 pretty sure the the dish or cup is out thats how they are one mine at least Quote
Gyra Posted October 10, 2012 Author Posted October 10, 2012 Ok, I've reinstalled the washers with the dish side out (ie opposite to the attached pic). The steering vibration has gone, but the vagueness remains - as if not enough positive castor angle. I'm booking in to Trutrack in North Melbourne for a wheel alignment next week, as they're quite close to where I work. I gather they're well respected, but suspect they could be pricey - any opionions? Cheers, G Quote
Riceburner Posted October 10, 2012 Posted October 10, 2012 You may have checked these already, but what's the condition of the steering rack rubbers, steering coupling rubber, ball joints? If you just get a front alignment it should be fairly cheap, around $30. Quote
luvemfast Posted October 10, 2012 Posted October 10, 2012 If you just get a front alignment it should be fairly cheap, around $30. Where you going? Never had one under $50 Quote
Riceburner Posted October 10, 2012 Posted October 10, 2012 Local tyre shop, in and out in 15mins. It's strictly just a front wheel alignment, castor/camber are non adjustable as is rear end. Quote
Moderators Zedman240® Posted October 10, 2012 Moderators Posted October 10, 2012 There are little "U" shaped shims that are used to adjust castor angle. They sit between one of the large cupped washers and the shoulder of the rod. May be needed if you want a wheel alignment.. Quote
Gyra Posted October 27, 2012 Author Posted October 27, 2012 Took the car in to the local tyre shop for a look and it seems the steering rack is shot. Was difficult to see when sitting on the ground, but up on the hoist we could see a fair amount of play. Any recommendations for where I can get the rack overhauled? (Melbourne north west). Or is there a modern replacement that's easy to install? Also the left rear has excessive toe-in (+12). Are there adjustable bushes available to fix this? I'm not looking for a fully adjustable suspension, just enough to set things good enough for normal road driving. G Quote
