pauly_adams Posted October 7, 2012 Posted October 7, 2012 hey guys, after a blown head gasket i thought i would rip th head off and replace it, thats where the pain started. when removing the head one of the head bolts snapped leaving about 12mm below the blocks surface, i tryed everthing to get it out easy outs, heat welding a nut on etc nothing worked so i resorted in drilling through the center of the bolt until it was thin enough to get it out with a tap which actully worked but the drill bit did damage a small section of the thread, so after all that i went through and cleaned out all the head bolt holes in the block all full of crud also then cleaned block and head then went to bolt it back down. i started to torque the bolts and got to the 2nd stage and the previously extracted bolt hole gave way and the block stripped. so what is the "best" method to fix the thread in the head stud hole as it is getting turboed and i dont want it stripping again cheers pauly Quote
luvemfast Posted October 7, 2012 Posted October 7, 2012 Is it ok to use a helicoil in a block? Not that there are many choices :-\ Quote
peter mc Posted October 7, 2012 Posted October 7, 2012 its very OK if there done right , make shore you use the long series Quote
luvemfast Posted October 7, 2012 Posted October 7, 2012 Basically, whenever working out threads. Ultimate strength is 1.5 X Diameter of thread. Helicoils are in lenghths x thread diameter. Example- M10 x 1.5D So the thread will be 15mm deep. In this case, in a block. I'd have to agree with Peter and get a longer Helicoil. So would a 2D be enough or would more be needed? Quote
pauly_adams Posted October 7, 2012 Author Posted October 7, 2012 yeh i was thinking helicoil, i have seen these new ones call "time serts" and am thinking of giving them a try as there a full case hardend bush any one used them before ? Quote
PZG302 Posted October 7, 2012 Posted October 7, 2012 As Lurch said Helicoil, and as others have said a long one. I've ended up with helicoils in just about every L series engine i've used to keep the h ead on, including one L18 that had a compression ration of around 12:1 and had that much taken off the head the A in the A87 for the head casting was a triangle and it was almost take a link out of the timing chain time. Quote
Scoota G Posted October 8, 2012 Posted October 8, 2012 One of these would fix it too. http://www.ebay.com.au/itm/JDM-L20-Turbo-Engine-L20ET-6-Cylinder-Motor-Nissan-Skyline-240z-260z-280ZX-/380483521280?pt=AU_Car_Parts_Accessories&hash=item589695cb00 Quote
peter mc Posted October 8, 2012 Posted October 8, 2012 Done right there stronger than the datsun thread , 2d is needed to do it right Quote
pauly_adams Posted October 8, 2012 Author Posted October 8, 2012 all fixed thanks guys, i managed to sretch 2 bolts and break another so i will be ordering new head bolts thankfully though i had a spare set from my L26 i will post up some picks of the head gasket its a bit of a mess im supprised the thing was still running Quote
