DreamZproject Posted March 26, 2012 Posted March 26, 2012 Hey guys, i was just wondering if anyone can clarify the legality of me having a 280zx engine in my 260z. I am aware that if a swapped engine is an option from the same car its fine, but this is obviously not. My main concern is if i have to go and get it engineered. The problem with that (besides the cost) is that it then should count as a modified vehicle, which i wont be able to drive for the next 3 years due to my P plates... Quote
Scoota G Posted March 26, 2012 Posted March 26, 2012 Of of the members here had exactly the same problem down in Geelong (blowed if i can remember his user name but i met him at Torquay Car Show) he obtained some litreature about the 280Z produce in the US which was an S30 chassis fitted with the 2.8 . . . This allowed him to register the car in Victoria. Quote
DAZDA Posted March 26, 2012 Posted March 26, 2012 http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx From that webpage; http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP3_Section_LA_Engine_01jan2011_v3.pdf Start reading... The following are Basic Modifications that may be performed without certification providing the modifications are carried out in compliance with the requirements detailed in Clause 2 General Requirements: Fitting a replacement new, used or reconditioned engine; Fitting a manufacturer’s optional engine together with any associated components as supplied by the manufacturer for that same model vehicle; Fitting replacement original equipment engine and exhaust components; Fitting replacement original equipment, equivalent or better, components that have no influence on engine performance or emissions (e.g. higher volume oil pump than original); Fitting equivalent engines with an increase of up to 20% of original power. In all of the above cases, if the engine is modified, it must be certified under the relevant Code of Section LA. NOTE: I should add, that as far as I'm aware each state has it's own legislation in relation to vehicle registration, but that most of the states have similar requirements to the NCOP. See below... http://www.vicroads.vic.gov.au/Home/Registration/PermitsModificationsAndDefects/Modifications/NotifyingVicRoadsOfChangesAndModifications.htm Quote
Agno Posted March 26, 2012 Posted March 26, 2012 I just finished a similar conversion on my brother's early model Skyline. Provided you fit the L28 with the stock fuel injection, all stock emission controls and equivalent suspension and brakes (already done) you should have no issue with registration. Tick "optional engine" on the engine number change form, provide the receipt for the engine with your name, sellers name and engine number and present the car for an inspection (check Vicroads for certified offices) and it's done. Quote
DreamZproject Posted March 26, 2012 Author Posted March 26, 2012 Bloody hell guys, what a response! i just called Vicroads, who palmed me off to Nissan, who then said, nup, we have nothing to do with it... THIS is the kind of information i need! Scoota, did he whack in a 280z motor, or 280zx? I think that will be the biggest difference... Quote
PZG302 Posted March 26, 2012 Posted March 26, 2012 Bloody hell guys, what a response! i just called Vicroads, who palmed me off to Nissan, who then said, nup, we have nothing to do with it... THIS is the kind of information i need! Scoota, did he whack in a 280z motor, or 280zx? I think that will be the biggest difference... 280Zx motor and 280Z motor are one and the same, both L28's Quote
Scoota G Posted March 26, 2012 Posted March 26, 2012 Bloody hell guys, what a response! THIS is the kind of information i need! Ask and thou shall receive Yep the 280Z and 280ZX motor are one and the same. Hopefully are Geelong friend may chime in or i'll see if i can hunt down his user name and you can PM him! Quote
DreamZproject Posted March 26, 2012 Author Posted March 26, 2012 That would be NUTS! I mean i do want to finish this car really well, but if i can do it whilst driving it too.... *DROOL* Thank you SO MUCH guys! Quote
luvemfast Posted March 26, 2012 Posted March 26, 2012 So does that mean you can put an RB20DE in? 2L twin cam cross flow triple carbs? Just like the S20 Quote
Scoota G Posted March 26, 2012 Posted March 26, 2012 Only took me 26 minutes to find it. http://www.viczcar.com/forum/index.php/topic,7086.0.html Quote
DreamZproject Posted March 27, 2012 Author Posted March 27, 2012 WOOOOOT thanks for that link. Now all i need to do is get the necessary information together (plus put the car together) and i should be good! Thanks very much for that guys. I think that that link you directed me to should be stickied, I'm finding that information is very difficult to find for yourself on this site. Maybe some more stickies would help... Quote
Scoota G Posted March 27, 2012 Posted March 27, 2012 Next time try googling what your looking for instead. Just for a laugh type in vic roads 260Z and you'll see that link will come up straight away. I just forget to do it sometimes, i'll never get that 1/2 hour back Quote
DreamZproject Posted March 27, 2012 Author Posted March 27, 2012 Yeah, im generally all for searching myself... but just typing vic roads 260Z got nothing for me... And having been someone that's read the post before, taking half an hour would suggest that its quite well hidden! I really do appreciate the effort, i just think that there should be some sort of better system for browsing, possibly more stickies or more refined topic titles (ie. engines has 3 stickies the rest of the information is a huge jumble)... Bust seriously, this has changed my whole view of how im going to build my car, and i really really really do appreciate all the help! Quote
Scoota G Posted March 27, 2012 Posted March 27, 2012 It's all in the wording, you can see that in that thread it vic roads is one word as in VicRoads. Quote
