datozed Posted December 23, 2011 Posted December 23, 2011 merry xmas to all im wanting to fit msd 6al2 box to my 75z does anyone know if i will need a msd tacho adapter and if so witch one cheers Quote
dat2kman Posted December 24, 2011 Posted December 24, 2011 Most others use an aftermarket tach, no probs thete, cant see why it wouldnt work with the stock tach Btw i have a brand new msd6al2 in box, with all the stuff they come with, for sale, bought it for a car, but found i already had a adjustable electronic ignition unit and higjer energy coil that came with it Quote
Riceburner Posted December 24, 2011 Posted December 24, 2011 I run the 6AL-2 and it worked without the adaptor on my autometer tach and also on my rebuilt 10,000rpm Datsun tach, should be fine. Quote
luvemfast Posted December 24, 2011 Posted December 24, 2011 How much you want for it Jason? Think I should fit one, more so for the rev limiter. Quote
d3c0y Posted December 24, 2011 Posted December 24, 2011 Stock tachometer will not work with the tach output from a 6AL or any other CDI. you can get an MSD tach adaptor or you can build one if you google tach adaptor 240z. It converts the stock tach from inductive loop to active low type. Pm me if you need the schematics. I even have bought the parts for a few if enough people are interested in it. gav240z 1 Quote
dat2kman Posted December 24, 2011 Posted December 24, 2011 How much you want for it Jason? Think I should fit one, more so for the rev limiter. It was for the 120Y, but we discovered IT had something as good, so sell the complete msd6al2 complete in box woth all the stuff it comes with thingy including postage to you, at $390 Even has fancy stickers too! Oh and its not the chinese ebay one! Quote
Six_Shooter Posted December 24, 2011 Posted December 24, 2011 Stock tachometer will not work with the tach output from a 6AL or any other CDI. you can get an MSD tach adaptor or you can build one if you google tach adaptor 240z. It converts the stock tach from inductive loop to active low type. Pm me if you need the schematics. I even have bought the parts for a few if enough people are interested in it. That doesn't apply to the '75. gav240z 1 Quote
Riceburner Posted December 24, 2011 Posted December 24, 2011 260z tach will work I've used one on my car with the 6AL-2, worked fine. 240z tachs have the inductive loop. Get one Simon, the rev limiter is very good. I've buzzed mine a few times at 7200 Quote
d3c0y Posted December 24, 2011 Posted December 24, 2011 I got a series 2 260z tach and pulled it apart because I thought the same thing and it's definitely still and inductive loop. I also used to have a 78 260z which I did the 280zx dizy upgrade an it still worked which is weird. Have you connected up the tacho to the tacho output from the MSD or just left it on the ignition? From what I have read about CDI ignitions the high currents they operate at will burn out the tacho electronics if left connected up with the loop. I just bought an autometer tacho because of this. Can anyone with a series 2 260z tacho handy have a look at the back of it and see if there is a wire looped on the back? Quote
datozed Posted December 27, 2011 Author Posted December 27, 2011 ok thanks to all looks like i will have to work out what tach ive got and take it from there Quote
dat2kman Posted December 27, 2011 Posted December 27, 2011 ok thanks to all looks like i will have to work out what tach ive got and take it from there My NEW msd6al2 genuine one, not chinese knock off, as avail, $390 inc postage. Can supply more if any wants, bulk buy 10 or more discounts avail. I will not supply crud, if any wants low cost, check out evilbay! Quote
neRok Posted December 28, 2011 Posted December 28, 2011 so i take it everyone is using these for the timing tuning ability, not just bigger spark? what dizzys are you using and how are you locking them out? Quote
Ben Posted December 28, 2011 Posted December 28, 2011 I'm using one (MSD-6AL) for the bigger spark only. The limiting is unused (ECU driven). Dizzy is L turbo (was custom locked up, hall effect). Quote
Riceburner Posted December 28, 2011 Posted December 28, 2011 I'm using my 6AL-2 for the bigger spark and the in built rev limiter, there's also a launch control function but I haven't connected that. I trigger it with a rebuilt scorcher dizzy (magnetic pickup). The tach I first used was from a 77 260 2+2 gap import and only had a brass bullet terminal for the coil trigger wire, this is the same tach I rebuilt to suit 10,000rpm and now runs straight to the msd tach (grey). If you connect anything to the coil it will be fried by the higher voltage the msd uses. Quote
Ben Posted December 28, 2011 Posted December 28, 2011 True story - only use the tacho output feed. I had my 240Z tacho modified with solid-state internals to suit the square-wave MSD output. I also have an MR30 tacho that I modified too - and that was already negative trigger, but didn't work properly with the MSD output Quote
d3c0y Posted December 30, 2011 Posted December 30, 2011 I use a Crane HI-6 with rev limit on a stock 240Z points dizzy. Cheaper than an MSD. Quote
datozed Posted January 4, 2012 Author Posted January 4, 2012 ok cheched out my tacho it is current loop type so i will need msd 8920 adapter gav240z 1 Quote
