aegean Posted April 16, 2011 Posted April 16, 2011 Looking for the following for a '74 260 Auto gear shift console - without cracks (I already have one of those) Auto gear shift knob Drivers side armrest - not warped Left/right plastic cover for seat adjuster Drivers side left hand spring hinge (arm that holds base and seat back) Mine leans to the left when you put weight on it, so I guess the spring is knackered Quote
MaygZ Posted April 16, 2011 Posted April 16, 2011 I should be able to get you the auto knob and the auto consol. I have a look tommorow and post some photos. If you're not in a hurry for them Loui can bring them back after the 15 of May. Cost would be a couple of cans of Jack for Loui. Quote
zeds4ever Posted April 16, 2011 Posted April 16, 2011 Simon, I 'm sure its for a 2+2 which are dfrnt to the two seater as you probably know. Craig, have a pr of 260Z 2+2 seat units & a center consul in which you would need to replace the metal centre plate that indctes what gear your in as existing plate is a bit worse for wear. I'm down your way next wed. If your interested give me a buzz at home. You've got my PH no. Regards: Alan. Quote
MaygZ Posted April 16, 2011 Posted April 16, 2011 Good points Alan, I should have read properly. Mine's even from a 240, so I don't know if they will suit at all. If they do, you are welcome to them Aegean. If not, then I hope Alan's suit. MaygZ Quote
aegean Posted April 16, 2011 Author Posted April 16, 2011 Will give you a call tomorrow Alan. Going to the GM day at Penrith today, followed by a BBQ - now that the rain has stopped in Sydney ! Quote
zeds4ever Posted April 20, 2011 Posted April 20, 2011 Hey May GZ, found out that the 260Z & 2+2 non adjusting seat support brkts are identical. Anyway all he needs now are the arm rests. His left one is Knckrd to just about. Regards: Alan. Quote
aegean Posted April 20, 2011 Author Posted April 20, 2011 Yep - starting to look good ! Thanks Alan. Photos of new interior. Quote
