e9 Posted February 7, 2011 Posted February 7, 2011 My door handle snapped off last night so I am in need of a replacement. Can anybody help me out? Quote
lightmaster240z Posted February 8, 2011 Posted February 8, 2011 I be leave you can use a 120y handle with a minor adjustment Quote
Sirpent Posted February 8, 2011 Posted February 8, 2011 I be leave you can use a 120y handle with a minor adjustment Correct, The mounts are slightly wider than the Zeds but the handles are physically the same item All you need to do is widen the screw holes on the door skin by about a mm each side for them to mount on. Cheers John Quote
Moderators Zedman240® Posted February 8, 2011 Moderators Posted February 8, 2011 depends on how yours has broken (arm past the pivot point or just the arm that operates the rod), you can swap your drivers side with the passenger side. Again, depends on how yours has broken.... Quote
e9 Posted February 8, 2011 Author Posted February 8, 2011 depends on how yours has broken (arm past the pivot point or just the arm that operates the rod), you can swap your drivers side with the passenger side. Again, depends on how yours has broken.... The pivot has completely snapped off both sides and I'll need to get a replacement anyway. Thanks for the 120Y modification suggestion but I want to get it on with as little fuss as possible. @galderdi, sent you a PM. Quote
nizm0zed Posted February 8, 2011 Posted February 8, 2011 There was some new repo's on evilbay a few days ago, may still be there. Quote
zeds4ever Posted February 8, 2011 Posted February 8, 2011 Think I have what you are seeking. But are 240/260/2+2 compatible. PM me please. Regards : Alan. Quote
e9 Posted February 8, 2011 Author Posted February 8, 2011 Think I have what you are seeking. But are 240/260/2+2 compatible. PM me please. Done Quote
