Has anyone actually installed a late model nissan brake booster into their 240/260? I have a selection of nissan passenger vehicle boosters but will likely use a z32 unit so that complying the eventual brake upgrade of z32 callipers front and rear, which I already have along with a handbrake solution, is cheap and easy, not requiring to pass a brake test. I stripped my 260 the other night and discovered the bolt pattern on the z32 booster is different. I have formulated a plan but thought "those who ignore history are destined to repeat it". I have located threads on calliper and handbrake mods but not booster mods, other than GM units. Anyone?
Usually just a master cylinder upgrade is all you need; I'm running a small 240Z booster with a 15/16 cylinder with Z32 calipers with no issues at all.
  • 2 weeks later...
??? Whats wrong with the 280Z srs1 , its a strght bolt up & is a 9" dmtr unit & there is no dramas with either brake master clndr 260 or 280 srs1. Unless you decide to go with the 280 series 2 modfctn brake master cylinder you will need the series2 booster as these are a hrzntl brke master cylndr bolt pattern.
        Regards : Alan.
I have 2 Z32 units already and if I can fit the entire brake system from the same vehicle the approval is merely paying for the engineer cert after they make sure the workmanship is OK.
worth while, tho a few mods are required, i think the last time i fitted a nissan dual diaphram and master cylinder off a N14 pulsar, i kept the pattern I made to fit it ,which i thought would save me a great deal of time when i repeat the procedure
