zeds4ever Posted October 18, 2010 Posted October 18, 2010 :-\ Having problems fitting chrome gutter rails to my 260z project. Read "Zedbacks restoration project" description of how 260z 2+2 has a sharper sweep over door section & that they are 60mm longer. Is this correct . Quote
gilltech Posted October 30, 2010 Posted October 30, 2010 I haven't got a 2+2 set here to compare with my 2-seat ones but that's probably about right, yes they are different 'cos the roofline is different being more angular where it kicks down on the 2+2. When I fit them I check them carefully to make sure they aren't too closed up anywhere, mask the car up to protect the paint, & roll them on by the heel of the hand gradually working along a bit at a time from front to back then repeat several times until they finally roll under & seat correctly. If your car has been repainted make sure there isn't too much paint build-up on the seams. Take your time, ease them on by hand, it's too easy to gark or dent the stainless if you knock them on with a rubber mallet or the like. Quote
RB30X Posted October 30, 2010 Posted October 30, 2010 I found that the 2+2's trim looked as though they would fit if you cut a small section off the end. They would require a slight bend to make the angle sharper and I haven't actually done it yet but I was under the impression it could be done. Also, for what its worth the chrome window trim between the outside of the door and the window from a 2+2 can work on a 2 seater too, once again, just chopping a small section off. Quote
zeds4ever Posted November 6, 2010 Author Posted November 6, 2010 Thanks for your response fella's, got hold of a set of 260's cheap. Have fitted one but can't locate the clips to install the other side. Need about seven clips in total. Don't now where I might buy them from do you. Also you might have problems with fitting 2+2 units as I think you will find they will kink to much when you try to bend them. Regards :Alan. Quote
peter t Posted November 13, 2010 Posted November 13, 2010 Do what I did and most panel beaters do. Put a dob of sikaflex where the clips used to be and clamp them on over night. Check my build thread. Quote
Scoota G Posted November 14, 2010 Posted November 14, 2010 Thanks for your response fella's, got hold of a set of 260's cheap. Have fitted one but can't locate the clips to install the other side. Need about seven clips in total. Don't now where I might buy them from do you. Also you might have problems with fitting 2+2 units as I think you will find they will kink to much when you try to bend them. Regards :Alan. I've got some clips you can have! Quote
zeds4ever Posted December 21, 2010 Author Posted December 21, 2010 Thanks heaps for the clips Mark. Cleaned them up & they worked fine. Will make donation as you requested. Regards : Alan. Quote
Scoota G Posted December 21, 2010 Posted December 21, 2010 Ahhh good squishy, glad to here you gotemok Quote
