Another cut required for rust repair.....
Hi guys,
It appears I have a more pressing need for the following cut.  My mate indicates this is beyond his skills to replicate.
I have attached image of rust area I need to replace.  I know this is a bit of a problem area in many Zeds.  Can anyone assist with a suitable clean cut or suggest an alternative?
Thanks
Thanks for that - will be helpful.
Seems like another peice was still used from a donor car though yeah?  Both inside and outside rail need work on mine.  Would like to get away with fabricating as little as possible.
If not other option presents itself - will give it a crack.
Cheers.
Hmm, yes, I still have to make up the template bit for that inner section hey? I'll put that on my to-do list for my holidays (it's getting longer with each day of leave).  ::)
If you get really stuck on the outside rail, you can make up some replacement sections, I was making mine before someone  ;D cut the front off my donor car and told me to stop being a pansy  ;) They're not too hard to make, I rekon if I had a crack at another piece it wouldn't be too bad, but a bit time consuming. But someone else's parts car would be the best and quickest alternative.
Good luck mate.
I have a half cut that you are welcome to come and cutoff what you need.  Give me a call on O4I99sevenseven 44 seven
MaygZ
Yeah - I know Lurch.
The guy doing it for me is not the most experienced - but I have "zero" experience - so have been following his direction.  He thought it would be easier to get a cut from another car, but having seen the other post with pic's - seems like it should be easier than I thought.
Will show him the post from scoota and see if he changes his opinion.
Maygz - reckon I may still take you up on your kind offer.  Just hold off until I hear back from my mate - see if he is willing to give it a crack without the cuts.
Cheers.
Shan
where did you get a half cut from??
We all have secrets, Benny Boy  8)
Shan,
you might need to be quick, I've had few inquiries about the 1/2 from others.
MaygZ
Like seagulls to a thrown chip..... ::)
I am away this weekend maygz, but if you could hold off until monday on the sections I have indicated - (drivers side front and passenger pillar) - I will give you a definite answer then.
At this point they are the only sections I require.....(god I hope so anyway!).
This topic is now closed to further replies.
