sydney mike Posted August 8, 2010 Posted August 8, 2010 I'm thinking about using some sound proofing material such as the stuff they sell at jaycar under my carpet/trans tunnel but not keen about using adhesive. Will it still be effective if I just fix it with some 2 sided? cheers Quote
Moderators Zedman240® Posted August 8, 2010 Moderators Posted August 8, 2010 Might work better with the added airgap in between the metal and the soundproofing... Quote
sydney mike Posted August 8, 2010 Author Posted August 8, 2010 Cool, i'll give it a go then. wasn't sure about the airgap thing. I thought the airgap might result in it being ineffective. The jaycar stuff is cheap anyway compared to dynamat. Quote
MaygZ Posted August 9, 2010 Posted August 9, 2010 I think that much of the effect of mat sound-proofing is that it stops the panel from 'drumming' or vibrating. I believe that this is achieved by sticking to the panel. As long as the panel is prevented from flexing, even a tiny 1mm movement will cause noise - (just look at how much noise you can get from a small speaker that will only oscolate a couple of mm?) - then you should be OK. Why aren't you keen to use adhesive? Are you planning on lifting it often? Personally, I would glue it down. m2c - MaygZ Quote
sydney mike Posted August 9, 2010 Author Posted August 9, 2010 Why aren't you keen to use adhesive? Are you planning on lifting it often? Personally, I would glue it down. m2c - MaygZ Not confident of my handyman skills-scared to screw it up. Quote
MaygZ Posted August 10, 2010 Posted August 10, 2010 It's sound proofing! It goes behind dash, under carpets and other trim? If you make a mistake or it folds on you, cut that section out and put in another section. Just take your time, work methodically - you'll be fine. Once you've done the floors and firewall, use of cuts to do the inside of the doors! It will cut down a lot of drumming. Don't forget, though, it will reduce the sound of your webers and straight through exhaust!! Quote
sydney mike Posted August 10, 2010 Author Posted August 10, 2010 Lol the glue being irreversible is what I'm afraid of screwing up. But I get what you're saying, once it's in why would you want it out Quote
Six_Shooter Posted August 11, 2010 Posted August 11, 2010 Even glue can be cleaned off. Sound deadening to be effective should be attached, I.E. glued to the metal you want to deaden. Quote
sydney mike Posted August 11, 2010 Author Posted August 11, 2010 I bought the jaycar stuff and a spray adhesive. Now just have to find the roller like the fibre-glasser uses. Quote
FLEXZED Posted August 11, 2010 Posted August 11, 2010 Hey mike i think i have one somewhere let you know when i have a look Loui Quote
