Shoot an email to Paul Woolf @ Zedbitz - he's in QLD. He should have one ;)
Paul (at) zbitz.com.au
you'll find that most japanese cars of that era use the same bolt.
quite often the same as the brake pedal bolt too.
opens up your options if your having trouble finding one.
Thanks guys- I've emailed Paul at zbitz, waiting on a response.
Peter - if he doesn't have one, I'll happily grab the one from your parts car - they're a bit of a pain to get to with the dash and wiring in the way (at least the brake pedal one was, the clutch pedal should be a bit easier I think.
Piece of pi## to get out. The door is off and one clip and it is out. Will get it out for you this weekend if you want. Probabily not as hard as the clutch line in the dark. Home Saturday morning if you want to come and get it. Cost you $0
  • 2 weeks later...
As per the topic - I'm in need of the bolt that holds the clutch pedal into the pedal box for my manual conversion? Anyone got a spare?
Thanks,
Ian
I used a 260z brake pedal bolt for my 240 clutch pedal, there the same :-)
