d3c0y Posted April 29, 2010 Posted April 29, 2010 Bought this dizzy out of an MQ Patrol L28 at the wreckers thinking it would be as easy to hook up to a 240Z as a 280ZX one. Stupid me. It doesnt look like it has an ignition module on it but maybe you dont need one being an optical sensor to just fire the coil. It also has 3 wires coming out of it. If this cant be made to work can it be used with an MSD 6-A or similer? Cheers Jake Quote
Moderators Zedman240® Posted April 29, 2010 Moderators Posted April 29, 2010 Most likely it will need an external igniter to fire the coil. The good ol' Bosch 022 modules are easy to wire up. The 3 wires could be positive, negative and pulse signal output at a guess. You will need a wiring diagram for more accurate details. You will have to find out if it runs on 5V or 12V and what wire is what. I'm just guessing. Quote
d3c0y Posted April 29, 2010 Author Posted April 29, 2010 External ignitor would make sense i wish i could have found teh patrol it came out of. Good for an MSD i guess... I should add that the optical gear inside has hitachi logos and the ID on the body is for a 280C or MQ Patrol. If i get an MSD i still need to get the distributor re-curved for better advance right? Quote
Enzo Posted April 29, 2010 Posted April 29, 2010 Hi Jake, Looks like you have a Crane XR700 electronic ignition trigger. It would have been attached to the ignition module. I have one on my 260z. A good simple system which has been on my Zed for about 4 years. Regards David. Quote
d3c0y Posted April 29, 2010 Author Posted April 29, 2010 Hey that looks promising - maybe a better find than i first though! Even better excuse to get an a/m ignition! Quote
Moderators Zedman240® Posted April 29, 2010 Moderators Posted April 29, 2010 Go back and grab the ignition module! hehe Quote
ChrisZ Posted April 30, 2010 Posted April 30, 2010 I have a Crane HI-6 and a LX-92 coil (45.000 volt), that i'm thinking about parting with, it's used, not new, i decited to use my NOS ZX dizzy. Now you know i have it and if it's has any interest to you, you can PM me. Chris Quote
d3c0y Posted May 1, 2010 Author Posted May 1, 2010 I bet that ignition at teh wreckers was long gone! Thanks Chris PM'd This is working out better than i had hoped. Quote
ChrisZ Posted May 5, 2010 Posted May 5, 2010 Buddy, i did reply your PM for the 2nd time, did you get it ? Chris Quote
