The exhaust manifold is designed for a draw through system , if you want to run fuel injection you are going to struggle with it as the turbo is sitting to high
the turbo manifold is cracked. If it has cracked once there is a fair chance it will crack again I wouldnt pay $200 for this motor just for the manifold
If you want a spare engine, then go for it.
However, if you want a turbo L-series, there's better ways to go about it...
