Has anyone had any experience with the K-Mac front camber adjustment kits? I'm getting some wear on the inside of my front right tire after installing some new (lower...) springs. (seems odd as the left tire is fine).
I had funny wear after fitting my lower springs too, went and got a wheel alignment and that sorted it. They can check camber and castor as well to make sure they're both even.
I think he's having problems with the front end Lurch, are the Robco adjusters for the rear?
Gyra, like Gareth said get a wheel alignment, If the caster is different side to side you may have bent something like a strut or bottom arm?
Thanks guys. I suspect the lower springs actually change both the camber and the toe - the lower arm is now more horizontal than before, therefore pushing the wheels towards more negative camber. I've got adjustable caster rods, so there is at least some adjustment available. Looks like a professional wheel alignment coming up after Christmas...
G
