Hi All,
Been doing some research, but I haven't been able to find exactly what I'm after. >:(
What I'm looking for is the white dial face stickers to suit a 260z. I know the Zed Store has them, but they are in MPH and I need KM/H. Does anyone know where I can find a set?
I saw the EL glow faces that SpeedHut have, which would be awesome!!...but again, they are in MPH  :(
Have you send speedhut an email to ask if they can do them in KM/H - I have some of their Revolution Gauges include a number not listed on their site :) I just had to order the imperial units and state in the notes for the order that I wanted them in km/h or bar or 0-15 PSI vis the 0-100 PSI etc whatever changes you required.
An email does not hurt - try it :)
i have speed hut gauges, easy to install, and they can change to km per hour and change the oil and etc measurements, just make sure u mention it in comments when you order.
Search "white face gauges" over at hybridz. There was km/h thread over their a while back with pics you could download. Not sure if it was the whole set but..
installing was pretty easy, just annoying taking out the gauges and putting them back into the dash. there is an guide thread somewhere on here
on either the speedo or tacho there is sometimes a small pin that holds the needle at 0, and i had to make a hole in my face plate which i was scared would wreck it but it worked out alrite but maybe u could get them to do that 4 u.
havnt painted the needles but that would be easy enough, i can see them very clear compared to the stock gauges because the face plates are very bright.
