hi all i need info on ford xd-xf disks for a 260z  ???
have done a r31 rear disk setup on my z
the disks i have are a hub type
i am using 17 inch multi fit rims so 5 stud on the front is OK
what bearings do i use
and what other things do i need
thanks if you can help
I believe the bearings are the same for Ford as well as Datsun - have a look at a set at your local parts retailer.
What calipers are you wanting to use?
:) thanks do you use a modified seal or standard nissan
i will use hylux calipers but extend the connecting points
or is there other calipers i can use?
sorry for the late reply been busy at work
but today my car came to life started after 2 years
all my wiring done and it started first pop
regards
I'd compare both types of seal, but I dare say they will be the same anyway.
You don't need to mod the Hilux/Landcruiser calipers as they are a direct bolt on to the Zed strut.
Try to get the later LN106 caliper too ;)
  • 2 months later...
ZZZ8 has that Hoppers Stopper kit on the front of his Zed.
Horrible sliding 2 spot caliper isn't great...
The 4 spot Hilux/landcruiser caliper with Nissan S13 or Peugoet 504/505 rotor is the go ;)
