Bruce Posted July 11, 2009 Posted July 11, 2009 I am in the process of swapping over the original L24 to L28. The L28 has an N42 head which has additional bolt holes to bolt up the EFI manifold. When using the original SU manifold these holes are not used. Can anyone recommend a tidy way of plugging them? cheers Bruce Quote
C.A.R. Posted July 11, 2009 Posted July 11, 2009 You don't 'need' to plug them Bruce, as they are a blind hole. But if you want to for aesthetic purposes, then a grub screw is the easiest way Quote
Moderators Zedman240® Posted July 11, 2009 Moderators Posted July 11, 2009 I can probably get some zinc grub screws to fit. Are they M8 or M10? M8 seems to be yelling out to me... Let me know if you need them. Quote
Bruce Posted July 12, 2009 Author Posted July 12, 2009 thanks for the replies. I'll check out whether they are m8 or m10 cheers just confirmed that they are M10, thanks Dimitri, but I'll grab some from the bolt shop tomorrow. Quote
