Thomo260 Posted April 10, 2009 Posted April 10, 2009 Just got the Z back and for the first time I can have a good look at it and I need to pick all your brains. While trying to balance the SU's, I have noticed a pipe going nowhere (see arrow in pic). Any ideas where it goes? And I am having a hell of a time trying to get the carbs evenly balance. The front carb is sucking air from somewhere and i am stuffed if I can find where. You can put your hand over it and the engine will still run. Hand over the back carb it stalls straight away. You can very easily hear the difference between the two even without the old hose to ear trick. Thanks in advance peoples. Simon Quote
Thomo260 Posted April 10, 2009 Author Posted April 10, 2009 The long pipe that goes over it runs to the rocker cover. This is a 77' 260Z to i forgot to mention but the carbs are most likley from an earlier model. Quote
Scoota G Posted April 10, 2009 Posted April 10, 2009 Yea they are the 240 round tops. Probably a good idea is to simplify the emission system but seeing as its after july 76 you would need a minium if your into keeping it all legal. Do you still run a air pump? Remember i'm local too so it's easy to drop in and have a look. This was one cure i found Quote
zzzzed Posted April 10, 2009 Posted April 10, 2009 i just went and took a picture for you The hose you have going to the rocker cover goes back to my carby however seeing you have round tops you cant do this, so you have one hose to many so you may as well remove the one not being used Quote
Thomo260 Posted April 10, 2009 Author Posted April 10, 2009 Yeah cheers, those triples would help my ego but not my wallet No airpump on the car either. I can see where a lot of 'tidying up' can be done by removing alot of crap and get away with emissions. As long as the fuzz that pull me over to check it isn't to switched on. Happy to take you up on your offer Scoot but it's got no reg so if your ever in the mood for a visit to Sebas? ;) Thanks for that Pic Mick. Yours looks alot cleaner without all the smog crap. Quote
Scoota G Posted April 10, 2009 Posted April 10, 2009 Happy to take you up on your offer Scoot but it's got no reg so if your ever in the mood for a visit to Sebas? Sure dude throw us a text or call on 0405 298411 Quote
Scoota G Posted April 10, 2009 Posted April 10, 2009 Scoots motto is: "Will work for Beer" Only for z club members.... otherwise check out my Facebook profile. Quote
Thomo260 Posted April 10, 2009 Author Posted April 10, 2009 I only drink spirits from a bottle. This could be interesting. Stuff it, i've got next week off so i will give you a call next week. Lets have mini club meet. Quote
Thomo260 Posted April 11, 2009 Author Posted April 11, 2009 I have removed the pipe and parts attached and blocked off the hole on the back of the air box. Now just need to fix the vacuum leak. Quote
Scoota G Posted April 15, 2009 Posted April 15, 2009 Simon's Z has a set of 1 3/4 triumph carbies on the thing...Playing up a bit but they would be possible to tune. Other than that there is this on Ebay http://cgi.ebay.com.au/Datsun-260z-extractor-bonus-whatever_W0QQitemZ150339139262QQihZ005QQcategoryZ130631QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting Quote
Thomo260 Posted April 15, 2009 Author Posted April 15, 2009 Thanks Heaps for dropping in Mark. You are a good man. Pulled the plugs out and the front 3 are all gummed up, back 3 arn't to bad buy I will get new ones tomorrow. Also set all the tappets today. Need to fix up some heater hoses and a few other things before I can go for a blap and get the timming right, then have another go at the carbs. Still the idle sits at almost 1000 and stalls if you get it down to 6-700. ARR the joy of owning a classic vehicle. Quote
