The reason im asking is because i recently acquired a reco'd R180 but its missing gasket for the inspection cover.
I called up Nissan, the guy said they were NLA, but i read somewhere that they came on the S13 or S14's i think, not sure. Just want to see if the gasket will be the same on the different diffs.
If some ones even got a part number for it,that'll be great.
Thanks
Sach, they are $19 new from Nissan.
Tell the Nissan guy to look harder.
S13/14/15 are R200, so they are NOT the same.
Nissan part no: 38320-U3011
In any case, I didn't have a gasket last time I needed one,
so I just wiped the surfaces down with prepsol/thinners & applyed an even coat of 'Blue RTV'.
It's never leaked...
Makes any size gasket for small engines and equipment
Gasket Makers
Loctite® Blue RTV Silicone Adhesive/Sealant
Remains flexible
Waterproof seal
Pressure resistant
Cures at room temperature
No need to screw down fasteners a second time after the product has cured
Temperature range: -65 degrees to 500 degrees Fahrenheit
Sach, the only Nissan spare parts guy I talk to is Trevor at Brighton Nissan. He goes out of his way to help Zed enthusiasts. Which dealership did you call?
The Nissan in Bundoora. I had heard that there was a guy in Brighton but didnt know his name, i know now. I'll be sure to give him a call next time.
