Roady Posted March 2, 2022 Posted March 2, 2022 Hi all, Just wondering for those using ATI balancers is there a preference or why choose the 7.074” (2.5kg) vs 6.325” (1.8kg). Obviously a larger rotational force for the larger one. Engine it would be going on: L28 L24 rods Flat top pistons 76 degree cam Triple Webers cheers for any help and suggestions Jason Quote
peter t Posted October 13, 2022 Posted October 13, 2022 Do you have to have an ATI balancer 'balanced' before fitting? Also the v-belt pully is sooo small, will I have to get a different v-belt?? Quote
C.A.R. Posted October 14, 2022 Posted October 14, 2022 6 hours ago, peter t said: Do you have to have an ATI balancer 'balanced' before fitting? No. 6 hours ago, peter t said: Also the v-belt pully is sooo small, will I have to get a different v-belt?? Do you mean the OD of the pully is small or the V-groove is narrow? Quote
peter t Posted October 14, 2022 Posted October 14, 2022 1 hour ago, C.A.R. said: No. Do you mean the OD of the pully is small or the V-groove is narrow? OD of pully is tiny, compared to original Quote
C.A.R. Posted October 14, 2022 Posted October 14, 2022 14 hours ago, peter t said: OD of pully is tiny, compared to original If you spend a lot of time in low RPM ranges, you might have a problem with the alternator charging. Stew Wilkins sells an larger pully/hub adaptor to rectify this issue. peter t 1 Quote
peter t Posted October 15, 2022 Posted October 15, 2022 9 hours ago, C.A.R. said: If you spend a lot of time in low RPM ranges, you might have a problem with the alternator charging. Stew Wilkins sells an larger pully/hub adaptor to rectify this issue. Thanks for the info. Quote
peter t Posted October 15, 2022 Posted October 15, 2022 15 hours ago, peter t said: Thanks for the info. On 10/15/2022 at 7:15 AM, C.A.R. said: If you spend a lot of time in low RPM ranges, you might have a problem with the alternator charging. Stew Wilkins sells an larger pully/hub adaptor to rectify this issue. I think I will just sell it if anyone is after one at a good price. Quote
240z71 Posted October 16, 2022 Posted October 16, 2022 3 hours ago, peter t said: I think I will just sell it if anyone is after one at a good price. Hey Pete PM sent Quote
