260DET Posted February 24, 2019 Posted February 24, 2019 (edited) Does Les Collins do this, if so what's involved and $. Basically a strong as possible job is required. Edited February 24, 2019 by 260DET Quote
C.A.R. Posted February 24, 2019 Posted February 24, 2019 I can answer pretty much any questions you have about the conversion Dickie and what Les does to them, however if you give me more information on what you are trying to achieve, I'd be able to give you a more accurate answer. Here is the basic conversion: https://www.viczcar.com/forum/topic/2434-tutorial-srca-gearbox-onto-l-series-engine/ Quote
260DET Posted February 24, 2019 Author Posted February 24, 2019 It's going behind a SR20DET, at this stage I'm costing a possible circuit toy project for a friend, the idea is to not go crazy with power which would require upgrades in several areas including a different, heavier box. A nicely balanced powertrain is the aim. So at this stage all that's required is a ball park price and power capability estimate plus the cost of a suitable core if applicable. Quote
C.A.R. Posted February 24, 2019 Posted February 24, 2019 (edited) So the vehicle is going to be a S13/S14/S15? Just spend the $500 to $600 on a good 2nd hand unit and the std S13/S14 71C box will be fine. Bearings kit ($250.00) and syncro rings (around $150ea) are cheap enough if you want to give it a freshen up. Gear sets with better ratios are available from Kameari: https://www.rhdjapan.com/kameari-super-close-gear-set-71c-s13.html If you are interested in getting Les to do the work, shoot him an email: http://www.lescollinsracing.com/contact Edited February 24, 2019 by Léon Quote
260DET Posted February 25, 2019 Author Posted February 25, 2019 Pic of Kameari gear set below, current price from RHD is $1,631.00 ex Japan. Are the gears wider than OE? Any other 'strong box' input welcome. Quote
C.A.R. Posted February 25, 2019 Posted February 25, 2019 3 hours ago, 260DET said: Are the gears wider than OE? Any other 'strong box' input welcome. No - they are the same width. Ratio's are different. The next upgrade over a 71C box is to convert to the much larger R33 turbo / Z32 turbo / VL Turbo MX7 This requires a cut and shut bell-housing at a minimum to mate to the SR20. I'm not sure on what else needs doing for this conversion. Quote
1600dave Posted February 25, 2019 Posted February 25, 2019 22 hours ago, 260DET said: strong as possible job is required. Strong as possible, or strong enough ? Quote
260DET Posted February 25, 2019 Author Posted February 25, 2019 My philosophy when doing something like this is to be informed of all possible upgrades and then decide which ones are worth doing , given the application and anticipated use. Quote
1600dave Posted February 25, 2019 Posted February 25, 2019 (edited) And that's a good philosophy to have. All too often people just jump straight to "biggest / strongest / bestest" without considering whether it is actually "best for purpose" Edited February 25, 2019 by 1600dave Quote
