Iceberg Posted December 15, 2018 Posted December 15, 2018 1975 260z 2 Seat Location: Melbourne Price: $30,000.00 cash or Bank cheque Details: Rebuilt mild race L26 Engine from Robco Engineering. · P30 L26 Block. · 1mm Overbore (2627cc). · New flat top pistons. · Balanced standard rods. · Prepped & balanced standard crank. · New water pump. · Turbo oil pump. · Winged & baffled sump. · BMW Harmonic balancer. · Billet steel flywheel & genuine Nissan 240Z clutch. · Cylinder head has been ported, fully reconditioned with new valves, springs, guides, ULP seats & stem seals. · 74deg works cam. · Full new KP gasket set used throughout. · 10.5:1 Compression Made 124kw on the dyno with triple 45mm Webers (no webers on the car now) Perfect street motor that can also be used for doing club motor-sport events that has done less then 10000kms (5 oil changes since being built). Restored and coated extractors Rebuilt 5 speed gearbox from Rob Z Car. King springs with adjustable shocks (Soft to Hard) Exceedy button clutch New flywheel Drilled and Slotted rotors Rota wheels with great offset (forgot the offset), fills up the wheel Arche and does not rub. Brand new chrome bumper OEM chrome mirrors Restored chrome tail light surrounds Restored fuel tank Rebuilt round top carbs New interior door handles – old ones were weathered 27-Piece Weather strip Kit installed for good seal: · Cowl-to-Hood Seal · Windshield Weatherstrip · Door Weatherstrip, · Door to Fender Seal, LH & RH · Lower Door Seals (on door) (both sides) · Window Channel Weatherstrips, Front, Top, Rear. · Window Channel Weatherstrip, Rear (in door) (both sides) · Upper Corner Seal, LH (in door) · Upper Corner Seal, RH (in door) · Outer Quarter Glass Seal (both sides) · Inner Quarter Glass Seal (both sides) · Rear Window Weatherstrip · Rear Deck Inner Weatherstrip · Rear Deck Outer Top Seal · Rear Deck Outer Side Seals (both sides) Quick Urethane Bushing Kit, for the control arms, sway bars, tension rods, steering rack, and moustache bar and Urethane Transmission Mount Bar Bushings Short Throw Shifter – great for traffic as it removed the long throws. Shift Boot, Inner & Outer I am sure I forgot other bits like naming hoses, break boost cylinders etc. The bad, or bits still to address. Original paint is good from far but far from good – faded and rough with front fenders not colour matched. I bought it like that. Fuel gauge is intermittently working Recently I got a fuel cut 2 times so seems like fuel issue but has not come back, never the less cheap fix. Definitely needs a carb tune to get the most of the engine. Couple of small rust bubbles that have been there since I purchased the car about 4 years ago, these have not progressed at all over time. Diff is ok, I was planning to find an LSD solution so have not replaced but diff is ok. All work has been done by my stepbrother who is a qualified mechanic. To finish the vehicle to what she deserves a respray, new carpet kit and re-upholstery, I would replace the short shifter as the throw is too short for reverse which was the reason I unnecessarily replaced the gearbox with rebuild one after installing the short shifter – it was not the gear box issue but the short shifter kit, easily reversible and cheap to fix. The car is registered on full registration and I drive the Z to the city and back in traffic without issues or a trip to the mountains when weather permits and when I can be bothered pulling her out of dry storage. Car is very nimble, lots of fun and gets loads of positive attention. I did get RWC certificate all of the above mentioned replaced items but wheels are debatable. Car is sold registered. Reason for sale: Since the Z lives in dry storage, I do not get to drive it so it does not make sense to pay full registration and full insurance. My qualified mechanic stepbrother is very unhappy with me for selling this car as he has put in many many hours of effort hence why some small issues not addressed and no RWC as he is not willing to help me sell the car. Need to figure out how to link more photos of the build. I will accept $30,000 - not negotiable Contact Via PM or Zero four zero three four five one eight eight eight gav240z 1 Quote
d3c0y Posted December 19, 2018 Posted December 19, 2018 Too cheap! 260Z are only worth less money than 240Zs because people won't list them at a high enough price! theremm, gav240z, OdinZ and 1 other 1 3 Quote
