Very Straight Front Grille (Slated Type)
It's not hard and doesn't take long to take it apart and paint strip it to bare metal. Any surface rust on the slats can be removed/polished off with fine wet'n'dry.
The weak parts are the aluminium uprights, they are soft and easily twisted.
I wouldn't blast it with anything except glass bead - because of the aluminium.
I found that a soft to medium wire wheel on the bench grinder worked fine for me , just don't get to heavy handed with it tho . Treat it as Giltech suggests then etch prime plus a fine coat of spray putty  should bring them up pretty good . Time & patience works wonders .
        Regards : Alan .
