PeterAllen Posted July 30, 2017 Posted July 30, 2017 I need to adjust the setting on my Arizona Z shocks - I think they are KYB brand. When I made the suspension I drilled holes in the bottom of each strut housing to insert a hex bar, with the intention of brazing on a 'T' handle to the end of the bar. It became a 'gunna' job. They are set so high up I can't get an Allen key to connect so before I muck around making something, it would be good to know the hex size. Thanks. Quote
peter t Posted July 30, 2017 Posted July 30, 2017 That's so unlike you mate. Sorry I can't help. Quote
260DET Posted July 30, 2017 Posted July 30, 2017 My metric keys came from Supercheep, they would be about 150mm long, I notice that generally keys are much longer than they used to be. Quote
600Z Posted July 30, 2017 Posted July 30, 2017 (edited) Hi Peter, There HSD shocks, I have a spare adjuster in my toolbox, it's 3mm. Though yours look like they could be larger from the pictures, get in touch with otomoto as they should be able to tell you the size. http://otomoto.shop033.com/p/8771201/hsd-damper-adjuster-clicker-monopro-type.html Justin Edited July 30, 2017 by 600Z Quote
PeterAllen Posted July 31, 2017 Author Posted July 31, 2017 Thanks Justin. For $18 I can get a set will come in handy for other jobs. http://www.ebay.com.au/itm/10PC-T-Handle-Hex-Key-Set-Allen-Key-Metric-Size-Quality-Hexagon-Spanner-Driver-/121957903527?hash=item1c6541eca7:g:Zl8AAOSw2GlXEc67 600Z 1 Quote
