cruzer Posted June 17, 2017 Posted June 17, 2017 Hi All, Just wondering if anyone has the following Chrome weather strips (runs along the roof water channel on the side of the car) Chrome windscreen strips Dash vent plastic cover (the plastic bit between the dash and the winscreen) Door cards I can be contacted on 0411 328 520 ThanksSam Quote
gilltech Posted June 17, 2017 Posted June 17, 2017 (edited) For 240 or 260? Which do you have? The door cards are quite different designs, with different armrests etc. The windscreen strips are stainless steel not chrome. The front set is the same for 240, 260 & 2+2. So try the ads on Gumtree etc for cars being parted out. By 'dash vent plastic cover' do you mean the full width filler panel between dash & windscreen? Mine is black painted metal not plastic. Edited June 17, 2017 by gilltech Quote
cruzer Posted June 18, 2017 Author Posted June 18, 2017 For 240 or 260? Which do you have? The door cards are quite different designs, with different armrests etc. The windscreen strips are stainless steel not chrome. The front set is the same for 240, 260 & 2+2. So try the ads on Gumtree etc for cars being parted out. By 'dash vent plastic cover' do you mean the full width filler panel between dash & windscreen? Mine is black painted metal not plastic. Hi gilltech, Thank you for the info. Being a newbie, I have a big learning curve ahead of me. I have the 260z (2 seater) version. Car didn't come with much of the interior, so trying to peice it all together. The dash peice i'm after look something like this. Quote
cruzer Posted June 18, 2017 Author Posted June 18, 2017 got 240 cards but they need recovering PM'd Quote
gilltech Posted June 18, 2017 Posted June 18, 2017 Every Z being parted out will have one of those finisher panels. However, the satin black paint is very thin and the panels are prone to rust. So find a good one but you may need to restore it. They have an imprinted texture in the metal. What year is your car? Nissan made several running changes to 260Z doors including relocating the winder and lock pull locations, which likewise affected the door cards. So you'll need to be careful to find the right ones that match your car. The 240Z cards are a less ornate design and the door pulls are different. Maybe they could be adapted to suit your particular 260. Certainly the door pulls are different so even if the 240 cards can be used you'll have to provide fixing points in the sheet metal to accommodate the pulls. Quote
cruzer Posted June 20, 2017 Author Posted June 20, 2017 Every Z being parted out will have one of those finisher panels. However, the satin black paint is very thin and the panels are prone to rust. So find a good one but you may need to restore it. They have an imprinted texture in the metal. What year is your car? Nissan made several running changes to 260Z doors including relocating the winder and lock pull locations, which likewise affected the door cards. So you'll need to be careful to find the right ones that match your car. The 240Z cards are a less ornate design and the door pulls are different. Maybe they could be adapted to suit your particular 260. Certainly the door pulls are different so even if the 240 cards can be used you'll have to provide fixing points in the sheet metal to accommodate the pulls. That was very informative. My car is a 74 260z 2-seater. Thanks for the heads up. worst case scenario, i'll have to make some up Quote
gilltech Posted June 20, 2017 Posted June 20, 2017 My car is also a '74 2-seater which I've owned for decades. I've found a great many differences between mine and the cars of subsequent years, Nissan made many running changes. I'm in Brisbane but if you have any questions I'll see if I can help. Quote
cruzer Posted June 22, 2017 Author Posted June 22, 2017 My car is also a '74 2-seater which I've owned for decades. I've found a great many differences between mine and the cars of subsequent years, Nissan made many running changes. I'm in Brisbane but if you have any questions I'll see if I can help. Thanks mate, Sounds like I'm in a for roller coaster of a ride Quote
gilltech Posted June 22, 2017 Posted June 22, 2017 Sounds like I'm in a for roller coaster of a ride All depends on what state your car or project car is in? You just have to be careful when buying parts that they will actually match or suit your particular car, don't just grab anything labelled '260Z' before checking. Quote
