240ZR Posted May 24, 2017 Posted May 24, 2017 As per title, I have the larger 16 mm adjustable radius rods. Thanx Quote
Agno Posted May 25, 2017 Posted May 25, 2017 I used bushes for a series 1 RX7 turned down to the right diameter for my larger radius rods Quote
PeterAllen Posted May 25, 2017 Posted May 25, 2017 (edited) I've use Falcon rods which are 18mm and the std rubber bushings slip over, i.e. no sleeve. If you have twin lock nuts on either side (!) you don't need a sleeve. Use 8 of these: http://www.ebay.com.au/itm/2-Pcs-M16-x-1-5mm-Pitch-Carbon-Steel-Retaining-Slotted-Round-Nuts-DIN-1804-/301967430218?hash=item464ea9524a:g:dWEAAOSw32lYuLmY If you're using polyurethane bushes then drill them out to 16mm. Edited May 25, 2017 by PeterAllen Quote
240ZR Posted May 30, 2017 Author Posted May 30, 2017 All good, got some from Stewart Wilkins Motorsport. Quote
