slimerz Posted December 2, 2016 Posted December 2, 2016 Hello, I looking to get the bracket that's welded to the fire wall under the dash. The steering column bracket mounts to it, and it can be from any model 240z, 260z, 260z 2+2. I'm doing a RHD conversion and need this bracket to mount to the fire wall. thanks mike Quote
PeterAllen Posted December 3, 2016 Posted December 3, 2016 Just carefully remove the LHD one and ask a fabrication shop to make a RHD version. Quote
CBR Jeff Posted December 3, 2016 Posted December 3, 2016 Mike The one welled on to the shell under the wind screen that is hidden by the dash board? PM datocam he may be able to help out with this. He has access to sections of cars. It should not be to hard to fabricate a bracket. It would not need to be original just functional (it is a left to right conversion after all and you dont see the bracket). Jeff Quote
Groundhog Posted December 4, 2016 Posted December 4, 2016 (edited) If you haven't already considered it, the windscreen wiper positions need to change for left to right conversion.If you are asking for the bracket get the windscreen wiper mechanism at the same time.GH Edited December 4, 2016 by Groundhog Quote
slimerz Posted December 14, 2016 Author Posted December 14, 2016 i purchased everything ells i needed a few years back from a guy in Australia. Just forgot about that bracket. I will pm datocam. Quote
slimerz Posted December 14, 2016 Author Posted December 14, 2016 CBR Jeff, is the person datocam? That name does not come up when I put it in to the message recipient. Quote
PeterAllen Posted December 14, 2016 Posted December 14, 2016 http://www.viczcar.com/forum/topic/13543-jeffs-240z-build/ Quote
