Hey Andrew,
I'm interested in the rear 1/4 panel that has been repaired around the petrol filler area.
http://www.ebay.com.au/itm/222238407097
Do you know who did the repair work on it?
Do you know if it was repaired using a Mig welder?
Just trying to determine if there is any distortion or low/ high spots around the repair.
A minimum amount is a reserve in a sense..
I think the only way you can start an auction on eBay at $0 and have a reserve set (that isn't know) is to be an advanced seller or use the advanced eBay auction set up.
It's a massive pain in the butt to do I've found...
So instead you set a minimum bid - which is a reserve price in a way. Guess it's all semantics.
