YosemiteZed Posted June 29, 2015 Posted June 29, 2015 Hi as the topic says Can anybody give me a supplier of front rubber control arm bushings preferably in NSW Cheers Phil Quote
44014 Posted June 29, 2015 Posted June 29, 2015 Repco, bursons, autobarn 2 seconds of searching in google http://www.whiteline.com.au/do_segue4.php?make=NISSAN&model=240Z&model_final=240Z+%28FAIRLADY%29&vehicle=10%2F1970-5%2F1974 Quote
dat2kman Posted June 29, 2015 Posted June 29, 2015 Tried Stewart Wilkins Motorsport? McGraths Hill area. Quote
dat2kman Posted June 29, 2015 Posted June 29, 2015 Repco, bursons, autobarn 2 seconds of searching in google http://www.whiteline.com.au/do_segue4.php?make=NISSAN&model=240Z&model_final=240Z+%28FAIRLADY%29&vehicle=10%2F1970-5%2F1974 Item required not listed with Whiteline! Quote
YosemiteZed Posted June 29, 2015 Author Posted June 29, 2015 All of the suppliers that I have had a hit on was for poly bushes and I am after rubber Phil Quote
fluegel Posted June 30, 2015 Posted June 30, 2015 Try this supplier http://www.zcarsource.com/ I bought my rubber from them. For the front I used nissan rubber control arm bushings and after market rubber tension rod bushings. For the steering rack and sway bar I used urethane . For the back they sell an entire rubber set. Quote
PeterAllen Posted June 30, 2015 Posted June 30, 2015 It's sometimes useful to do a search - I made the same inquiry last year and purchased from the recommended seller. http://www.viczcar.com/forum/index.php/topic,14533.msg154477.html Quote
