andoi Posted January 24, 2015 Posted January 24, 2015 hi All my brake booter has failed and i need to get a new one, i have read that the ones on the 280zx are a straight swap - so if that's correct ill go for either. please help as my baby was running so well until this Quote
theremm Posted January 30, 2015 Posted January 30, 2015 hi All my brake booter has failed and i need to get a new one, i have read that the ones on the 280zx are a straight swap - so if that's correct ill go for either. please help as my baby was running so well until this Just get it rebuilt. Mine just failed in '73 240z. Cost me ~$260 and now hopefully good for another 40 years (you'd like to think) Quote
andyk_79 Posted January 30, 2015 Posted January 30, 2015 +1 for getting it rebuilt/reco'd. My research when I had mine done turned up that there were 2 or 3 different specs of booster in the 240z alone, some of them with different bolt patterns (not interchangable). The 280 booster is larger so you will be over-braked and the bolt pattern is different from the 240's from memory Quote
andoi Posted January 30, 2015 Author Posted January 30, 2015 thanks all, @andy k - i read that the 280 unit is a straight swap only with the '73 240, but yeah i think that around the $300 mark for something that is gonna last around 40 years is pretty good value, as far as rebuild goes - can anyone recommend somewhere to go? thanks again Quote
Cozza Posted January 30, 2015 Posted January 30, 2015 Not sure of your location but I had mine done in the Sutherland Shire by Weldon Brake and Clutch. I find them to be very reasonably priced and can normally get hold of anything I need. http://www.weldonbrakes.com.au Cheers Mick Quote
andoi Posted January 30, 2015 Author Posted January 30, 2015 sweet - not my area but i can travel, thanks Quote
