Kirby Posted December 13, 2014 Posted December 13, 2014 Hey guys, Looking for a full set of struts, hubs and control arms for a 260z that I can rebuild. Parts I need: L/R Strut Tube (55mm OD) Front L/R Stut Tube (55mm OD) Rear Front Hubs Rear Spindles (27 Spline) Front Lower Control Arms Rear Lower Control Arms Strut tops (F/R) Parts that I don't need: Bearings Wheel Studs Calipers, Rotors or Brake Lines Shocks, Springs and Gland Nuts Ball-joints Companion Flanges Happy to take from a 2+2 as long as someone can confirm with the spring perches removed they are the same as my 2 seater items. Cheers. Quote
gilltech Posted December 13, 2014 Posted December 13, 2014 All the 2+2 rear struts I've seen have been taller than the 2-seater ones. Might have a few bits, I'll have to dig into my stash of parts. Quote
d3c0y Posted December 13, 2014 Posted December 13, 2014 44014 and Deus Ex on here have complete sets of control arms they dont want and Deus Ex will have a set of strut tops and 240Z front hubs and rotors. Quote
dat2kman Posted December 13, 2014 Posted December 13, 2014 Have a pair of rear lower arms, not bent. And strut tops, rubber in vgc. Location Brisb West. Quote
gilltech Posted December 13, 2014 Posted December 13, 2014 240 front hubs are different to 260 are they not? Quote
d3c0y Posted December 14, 2014 Posted December 14, 2014 That's why i mentioned they came with rotors, so if you are running stock brakes, you will see no difference. Quote
Kirby Posted January 16, 2015 Author Posted January 16, 2015 Still looking for all of the above. Cheers Quote
