Advertising for a friend.
Engine: RB25
Pistons:forged JE 10.5 comp ratio
Rods:spool/ARP 2000 rod bolts
Injection: 2000CC Bosch injectors/E85 with Turbosmart FPR1200 regulator
Twin wilbora pumps with carter black lift pump/2ltr surge tank/custom swirl pot on bottom of stock tank
Head:Valves recut 3 ways
Heavier valve springs
Cams 256/256 8.5 lift Pon cams
Oil system: 7.5 Ltr custom baffled sump. N1 oil pump with billet gears/crank collar spool.
3 qrt accusump with non return valve at oil filter. Oil cooler with remote filter. Rear spool head drain. Savage pump on oil catch can.
Turbo GTX35R ball bearing/.86 Rear housing.
ECU: Haltech platinum with Haltech Dash/ have Topstage Composites dash to be installed in carbon fiber to go with the car. Microtech X6 ignighter pack with Bosch coil packs.
Trans:custom clutch single plate 3200 pound direct clutch services
  Stock RB25 transmission.
Diff: custom Long nose LSD centre from S13 Silvia. Custom mounted diff.
Wolf Creek Racing half shafts
Suspension: Arizona zed car race adjustable struts.
WRX STI power steering rack 2.5 turns lock to lock.
Adjustable A arms
Adjustable caster rods
Teckno toy rear adjustable Rear lower control arms.
Brakes: front 6 piston willwood calipers/315mm rotors
Rear 4 piston willwood rotors/295 mm
Willwood brake bias controller
Master cylinder 15/16" 280zx
Booster R33 skyline duel diaphragmed  type.
Roll Cage: 6 point
Seat: Race Tech / 5 point harness
Aero: front splitter Topstage V2
Rear splitter and spoiler Topstage in carbon Fiber. Flares dry carbon
Any other question please ask Jeff
$30000  ono
dat.240@hotmail.com
http://www.speedhunters.com/2014/10/tin-top-tango-five-interesting-cars-from-wtac/#chapter-rb25det-powered-260z
I owned this for a few years,
Current owner has done a very good job removing rust, and repairing the shell, prior to re- engining the car.
It's lcated in Brisbane Northside.
Just like to point out that developing a good track car takes a lot of time and money. The true cost is lost in the on going development and the must haves along the way. My point is if you build a car like this from a stock base car the cost will blow way out. So these cars or though not cheap, are good value. Just ask anyone who has ventured down this long road.
Jeff works for Bechtel up in Gladstone, mine industry, 4 weeks on, 1 week off etc.
You just need to try him at different times of day to catch him.
I get calls from him from some interesting lcations, he was doing fly in/flly out at Karratha in WA for a while.
  • 1 month later...
When was the last time this car had panel & paint and is there a build thread on it anywhere? and what work would be required to license it (in another state)
The white car above, has been sold, IIRC.
What are you after, and for what category of track use?
I'm selling a GpS Prod Sports Z.
