Jasonisa Posted September 11, 2014 Posted September 11, 2014 Hey guys the same burke who muddled up the removal of my tensioner also did not take note of which bolt went where when he took the timing cover off (safe to say he wont be touching my car again) does anyone have a guide or diagram about what size bolt goes where on an l28 timing cover Cheers Quote
dat2kman Posted September 11, 2014 Posted September 11, 2014 Oh my gawd! Burk,, love it! Ok easiest way is to use the depth rod stick thing that pokes out end of a slide verniers, and check depth of each hole WITH the timing cover held in place by hand. Before you even fit gadkets or sealants to gadkets. I just hope he remembers the two small bolts that attach head to timing cover. One of the timing cover bolts also holds on the strap that is the adjuster for the alternator, that bolt may have extra eadhers, to align the long curved slotted bracket square. Hope this helps! Quote
MaygZ Posted September 11, 2014 Posted September 11, 2014 The other way is you call PMC and ask him to give me back MY timing cover bolts. When he sends them back to me, I'll work it out and let you know Quote
