Riceburner Posted August 28, 2014 Posted August 28, 2014 I will be requiring a girdle for my stroker engine. I have come across one that is a little different but I'm unsure if it will do the job or not. It's billet aluminium, it only attaches directly to the main caps 2,3,4,5,6 and sits inside the block. Would it be ok, strong, weak, useless? With the huuuuuuuge extended sump I have, clearance to the steering rack is tiny. I'm concerned the sump will hit the rack with the regular girdle fitted. Quote
dat2kman Posted August 28, 2014 Posted August 28, 2014 Same as Nissan SR20DET It'll sorta help, ideally a full set of custom made caps, and a plate from one side of block to other, dowelled into block edges, and studded mains. Sump then bolts on, or the alloy AZC type sump, ideally dowelled ( dont come prepared for dowels) The blocks can spread/twist, the drag race boys know all about this! Mate runs a fj20 staged at 35 psi, then ramps up to around 50+ psi boost, block is concrete/grout filled, girdle is 1/2" thick plate, tied to sides and mains. Car does 7.1s. 1/4 mile. Has the quicks indeed. Quote
Riceburner Posted August 28, 2014 Author Posted August 28, 2014 So this style would be better as it ties into caps and all around the block? And it's steel I only have about 5mm clearance to the steering rack so this type will make it very very tight. Quote
KatoKid Posted August 28, 2014 Posted August 28, 2014 I cant see much benefit in the alloy one Gareth, tying the tops of a few caps together wont hurt but wont do an awful lot either. Full steel girdle is much better if designed and fitted properly. If you really think you need a girdle then having to do a minor mod to your oil pan is an easy option. Quote
Riceburner Posted August 28, 2014 Author Posted August 28, 2014 Yeah when you think about it that way it makes sense to stick with the proven product. Thanks chaps Quote
d3c0y Posted August 29, 2014 Posted August 29, 2014 I had a plate steal one when I was getting my engine built and PMC said not to bother with it so i sold it. The block isn't designed to need a girdle and I am running a Kameari/AZC sump which helps stiffens the block. How much power is your stroker going to make and how hard are you going to rev it? If it's less than 400hp at the crank and under 9000rpm I think your money is better spent elsewhere. Quote
Riceburner Posted August 29, 2014 Author Posted August 29, 2014 I had a plate steal one when I was getting my engine built and PMC said not to bother with it so i sold it. The block isn't designed to need a girdle and I am running a Kameari/AZC sump which helps stiffens the block. How much power is your stroker going to make and how hard are you going to rev it? If it's less than 400hp at the crank and under 9000rpm I think your money is better spent elsewhere. Very interesting, If your engine doesn't need one I can't think of many that would! I'll be nowhere near that power, I can't see myself revving it past 7500ish. Which block should I use? I have F54, N42 and an L20a six cylinder. Quote
dat2kman Posted August 29, 2014 Posted August 29, 2014 I like to call it "insurance" or " peace of mind" ! Quote
peter mc Posted September 1, 2014 Posted September 1, 2014 just built a L 31 stroker with a 600hp turbo,, thing is mad running 25psi making well over 500hp engine ,, just studs and a sump... ,i have had it apart to check things , no sign of problems Quote
