Dan260Z Posted July 3, 2014 Posted July 3, 2014 Chasing the t-piece that's usually bolted under the rear of the car, just in front of the rear axle line (under the rear seat area on a 2+2). Pic attached. As I'm using it to adapt Volvo 240 front calipers to my s30, it'd be great if someone could sell me one with the hard lines that run over to each rear wheel included - or if the lines have been cut, at least roughly 8 inches / 20cm or so of the remaining lines (so I can add the different flare to suit the volvo calipers to the other ends). Offering $10 (based on new generic ones costing about that much on ebay - only I prefer the zed type so it matches the one I have) + postage (or happy to pic up if you're in Melbourne). Cheers, Daniel Quote
dat2kman Posted July 3, 2014 Posted July 3, 2014 Go to a wreckers, pretty well most Jap cars will have one of these in engine bay on firewall, or if car upside down or up in air, at back. Usually a 10 ringy and a pair of sidecutters to remove. Quote
Dan260Z Posted July 4, 2014 Author Posted July 4, 2014 Cheers mate, will certainly go to the local pick-a-part if this turns up nothing - thought I'd start off asking here so I was sure to get one that matched the one I have on the other side (helps with my OCD and all :-P ). No doubt I'll find two the same though (with zed-type double flares and M10x1.0 nuts) if I look hard enough. In the meantime if anyone has a zed one let me know Quote
KatoKid Posted July 4, 2014 Posted July 4, 2014 Good brake shops will have them for 10 bucks. Dont muck around with old brake lines, while you are there buy some new line and flare nuts....total cost should be around $20 Quote
KatoKid Posted July 4, 2014 Posted July 4, 2014 If you are eastern suburbs go to Better Brakes in Bayswater Quote
