dat240z Posted January 12, 2014 Posted January 12, 2014 Can you guys confirm if the EBAY rust repair panel is suitable for 240z without modification....? Im assuming its just a weldin process. It states 260 2+2 and 240z compatible.... Quote
Administrators gav240z Posted January 12, 2014 Administrators Posted January 12, 2014 I was wondering same thing actually. My assumption is that you will need to trim it down for a 240z but it would be good to confirm if this is true. Is the pattern of this panel the same between years? Quote
Scoota G Posted January 12, 2014 Posted January 12, 2014 The 2+2 panels are slightly different. They are an exact match for the 2 Seater. Quote
Scotty_Rah Posted May 9, 2014 Posted May 9, 2014 I just bought one of these for my 2+2. Does anyone know what sort of modifications it takes to make it fit? Quote
Scoota G Posted May 10, 2014 Posted May 10, 2014 I just bought one of these for my 2+2. Does anyone know what sort of modifications it takes to make it fit? They are just a different shape on the ends and doesn't go all the way up to the inner lip like the original one does. You can extend it if you like but the rubber hides the gap anyway. Keep your old one after you drill out all the spot weld because you can use it as a guide to drill out the new one for plug welds or if you have a strong enough spot welder for the same purpose. Quote
Scotty_Rah Posted May 12, 2014 Posted May 12, 2014 Thank you Scoota I don't really have the one i spot-weld-drilled off.. it was in pretty bad shape I've got only a little piece of it left.. I'll have to find some other way to fit it. I'm sure i will. Quote
