Topstage Posted November 28, 2013 Posted November 28, 2013 long story cut short, supposed to be an expert in zeds totally stuffed an LSD conversion. i need someone to rebuilt the clutch pack LSD. it has massive play on it, not kidding the bolts on the drive shafts was hand tight!!!! i was lucky to actually go over the whole car's fastener. preferably in Victoria thanks guys. Quote
Whoray Posted November 28, 2013 Posted November 28, 2013 Christ Wood in eastern suburbs of Melbourne. 9877 203 two or 0438772 03 one Quote
Riceburner Posted November 29, 2013 Posted November 29, 2013 +1 Chris set up my diff years ago, lock wired everything. Top notch work, good bloke and very well priced. Quote
dat2kman Posted November 29, 2013 Posted November 29, 2013 The clutch pack centre is most likely untouched and will be fine. By sounds of it the bad shop ( name??) has just thrown the centre into a housing, hopefully the CW and the Pinion gears are matched, and not bothered to shim out the backlash, to get the " free play" out of it. Nuts/bolts loose? Surprising enuf, many workshops do overlook, and forget to do final spanner check on everything they touch. What was the clutchpack centre out of? Quote
C.A.R. Posted November 29, 2013 Posted November 29, 2013 Les rebuilt my R200 with a OS Giken centre last year - did a top notch job. www.lescollinsracing.com/contact Quote
zed240au Posted November 29, 2013 Posted November 29, 2013 Pity your on the wrong side of the water Freddie would have been happy to rebuild it for u just did mine car is launching so much better with a tight lsd Mick Quote
