  1. Yesterday
  2. I ran the group buys with the parts and panels supplied by Resurrected Classics in the USA as they were the only supplier at the time. It ended up being an expensive process. The prices listed here https://allmusclecarparts.com.au/datsun/240-260z.html are much cheaper. I'm not sure how much you'd save by importing them yourself, but best of luck.
  3. Last week
  4. Yep. Just as I remember it. Get the whole thing media blasted (by someone whos knows what they are doing) and locked up in Epoxy. Then start the repairs.
  5. And here's the pictures of the remaining repairs:
  6. Ok, some pictures of where we're starting from. This was @Linton's second car, that he'd started before his tragic accident. I realise now how much work he'd done. The roof has the worst surface rust, though a few spots on the bonnet might be worse. I think the roof is salvageable, based on no experience but just wishful thinking! 😎 Linton fixed some front end damage to both guards. Fitted a new radiator support panel. Made and installed new rust cuts under the battery, and to the LH side of the firewall. Repaired rust around the top of both taillights and the "slam" panel. (I'd call it the hatch sill?) He also did some repairs to the LH chassis rail, but unlike the other repairs which were highly documented I don't have any pictures of that apart from the very initial condition. So I'm not really sure how deep that repair went. Still to do: LH sill and bottom of the A pillar. RH bottom of the A pillar. RH rear of the door, and the RH dog leg. RH front of the door. Two spots on the LH door where I think a chrome trim strip was attached. Dodgy fibreglass repair to correct on the bottom of the LH guard. And the bottom of the support panel inside it no longer exists. Plus what I haven't found yet. I don't think the radiator support panel is parallel with the firewall. Not sure how or why, but we might have to install the bonnet to see what the alignment is actually like. So, that's the fun that awaits. Not sure what we can do ourselves, mig welding sheet metal is new. Ideally we'd practise on offcuts first, and non visible parts of the car. But next: media blast the whole thing and 2k epoxy is the guidance we've received. Cheers, Richard
  7. Earlier
  8. NickF
    door alignment
  9. i think i saw some 'group buys' on the forum in the past would people want any of the panels to share freight
  10. saw that. appears to be 300%+ ,markup over the factory price. must be the shipping
  11. C.A.R.
    door alignment
  12. If you want china panels, you can get them here in Australia: https://allmusclecarparts.com.au/datsun/240-260z.html Do they fit? Yes. Are they OEM quality? No.
  13. Stuff has started appearing on Aliexpress. Has anyone bought any of them and does it fit?
  14. NickF
    door alignment
  15. Measure the thickness of the original panel, then replicate in the appropriate thickness steel. 0.7mm & 0.95mm cold-rolled are both available from steel merchants.
  16. Back from a break so back on this topic Need to make a couple of patch panels , presumably 1 mm and 1.2 are the way to go? When I measured up some of the parts, they seemed to be only0.7 to 0.8 though Presumably these are the standard sizes in Oz Cold Rolled Steel Sheet - Melsteel
  17. Did you sort the dimensions? are the plans incorrect?
  18. BOT alert. Gavin or admin please have a look.
  19. https://GirlSingle.com Find a girl who shares your desires [url=https://GirlSingle.com] Real Girls. Real Nights. [/url]
  20. It's on again! Date: Sunday 29th November 2026 Time: 11am Onwards. Location: Same as previous years, Gordon and Sharon's property in the outer East near Lilydale. Please prey for dry weather! PM me or @Gordo for the address if you haven't been before. Bring your Zed, food and Drink and a chair. The wood fired BBQ will be provided. Bring your Wives , partners and kids. All welcome!
  21. Just media blast it or soak it in a 4:1 Water & Critic Acid solution.
  22. Experiments in dealing with rust coming up. Chemical rust removal, chemical rust conversion (iron phosphate and zinc phosphate) and mechanical removal. Start with small less rusted parts. Any tips appreciated! Supplies and advice came from Milsome's Auto paints in Ferntree Gully, they seemed very good.
  23. Will add this one to my list: https://bringatrailer.com/listing/1967-datsun-411-sss-wagon/
  24. AI can be hit and miss. I asked AI the length of the Z car bonnet, it said 2.4m. Ah, that’s the car length. Now it says 1.6m. I think it’s closer to 1.4. I’d assume you have some packages of hardware bolts, just try some and see what it is. Or take the handle to Bunnings and find some loose bolts to test. Actually, on mine, it looked like a pin was used, so AI is wrong again about it being a screw. Some probably are, but not all, I suspect.
  25. not m4 as it says here? What’s the thread pitch?
  26. Yeah neither of my shifters has them. I’d buy new anyway if I was you….
  27. Thanks! Despite people saying the bumper mounts were too high, the pics of rotisseries did suggest they were actually too low!
  28. Convert it to manual transmission, and you wont have to worry about the screws (you can buy them from your local bolt shop - M6 counter sunk)
