datsfreak Posted April 6, 2009 Share Posted April 6, 2009 Hi, I thought i'd share how to fix the signal switch in 240z's. Ive done this mod on two 240's ,including my current car which have been working for about 5 years. Thr original switch often gets a bit dodgey - its over 35 years old. It is very difficult to clean as the switch has a crumby bakalite back that falls to pieces when you try to open or close it. The idea is to remove the switch then: Make a plate with three holes , 2 are the original screw holes and a large center hole that is centered on the plate between the screw holes. I used a two way toggle switch that was spung to return to center. I got it from dicksmith, but you could get them from jaycar. I think it was only $3-$4. Put this in the center hole of your new plate ,so it sticks into the workings of the indicator stick. Its a bit tricky getting the depth right, this is adjustable by the two nuts on the new switch - the goal is to get the signal stalk to work as original WITHOUT pushing the new switch past its limits and also to work the switch enough to trigger it.- Its trial and error but it doesnt take long to get it right. I cant remember the wiring but it was very straight forward using the original wires. Anyway I hope this picture will help. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted April 6, 2009 Share Posted April 6, 2009 Bea u ti ful i did the same thing to fix mine about 10 Years ago and it still works. Quote Link to comment Share on other sites More sharing options...
zedls1 Posted April 11, 2009 Share Posted April 11, 2009 Hi datsfreak, Glad i found the topic. When I indicate left nothing happens, it worked intermittently yesterday and then stopped working, right side no prob. If one side works and not the other is the switch still the prob? I checked bulb, that was ok so i thought there must be something wrong with the switch, so i think i'll give your recipe a shot. Regards John Quote Link to comment Share on other sites More sharing options...
zedls1 Posted April 13, 2009 Share Posted April 13, 2009 Hey datsfreak/scootag, hope you've had a great Easter. Just a little question, does the toggle switch need to be of a certain rating, volt, amp etc..? Thanks John Quote Link to comment Share on other sites More sharing options...
Scoota G Posted April 13, 2009 Share Posted April 13, 2009 Mine wasn't. Just a standard Dick Smith item. Only thing i did different was to trim the stalk of the switch by 5mm. Quote Link to comment Share on other sites More sharing options...
RBZ 260 Posted April 14, 2009 Share Posted April 14, 2009 few more companies that sell lot of swicthes. varius ratings etc..... you pay a fair bit as ive seen swiches fetch over 100 each. but u may get a easier install one. good tip though. only issue i have is those swicthes are ok but sometimes the springiness wears out too quickly. my previous work used them for selecting between lpg and petrol.3-4years need replacing. i guess some z are not driven daily through the suburbia. anyway for HUGE selection of swiches visit these guys. if not lucky to have the counter in the state u are at,can get stuff over the line quite easily and posted to your doorstep. Also lot of other goodies like EL Sheets solenoids map sensors , LEDs etc.... but very $$$$ http://au.farnell.com/switches or http://australia.rs-online.com/web/search/searchBrowseAction.html?method=browseSuperSection&Ne=4294960157+4294964839&N=4294863123 Quote Link to comment Share on other sites More sharing options...
datsfreak Posted April 15, 2009 Author Share Posted April 15, 2009 Hey datsfreak/scootag, hope you've had a great Easter. Just a little question, does the toggle switch need to be of a certain rating, volt, amp etc..? Thanks John Nah - It didnt need anything high rated , mine has lasted 5 years now and if it died next week its only $5 and 30minutes to fix. I think this is the switch i used: http://www.dse.com.au/cgi-bin/dse.storefront/en/product/P7689 If I remember correctly I connected both poles with solder to help with the rating. Quote Link to comment Share on other sites More sharing options...
zedls1 Posted April 20, 2009 Share Posted April 20, 2009 Hey datsfreak, Worked a treat. The only thing is it won't self cancel. Thanks John Quote Link to comment Share on other sites More sharing options...
stevo_gj Posted April 20, 2009 Share Posted April 20, 2009 The only thing is it won't self cancel. Did they ever? I think mine is still stock and it doesn't. Quote Link to comment Share on other sites More sharing options...
zedls1 Posted April 20, 2009 Share Posted April 20, 2009 Hi stevo_gj I'm sure it did, you've got me scratching my head now, maybe i was switching it off subconsciously. Mine is a 73, did the early birds not have the feature. John Quote Link to comment Share on other sites More sharing options...
nuclear_z Posted April 21, 2009 Share Posted April 21, 2009 all cars in the 70s were required to self cancel... Mine self cancels, however the switch is dodgey Quote Link to comment Share on other sites More sharing options...
Vindicare Posted May 9, 2009 Share Posted May 9, 2009 I believe most of the time self canceling not working is a product of the tab being missing or broken off the back of the steering wheel. Normally aftermarket wheels dont work. My 1973 240z self cancels with a stock steering wheel. Quote Link to comment Share on other sites More sharing options...
zedls1 Posted May 9, 2009 Share Posted May 9, 2009 Hi Vindicare, I think i've got to modify the toggle on the switch, as in make it thicker because the actual indicator stork does return to the centre position and then i have to give the stork a little up or down flick to move the toggle in the off pos. The original part is like a knob that fits in the hole with no slack on either side hence cancels if that makes sence. John Quote Link to comment Share on other sites More sharing options...
Michael Posted May 9, 2009 Share Posted May 9, 2009 My Zed Self Cancels / indicates just like a modern car, I Might have a look tomorrow, after reading this topic... Quote Link to comment Share on other sites More sharing options...
towndrunkensmurf Posted May 9, 2009 Share Posted May 9, 2009 hmm i cant even remember if mine self cancelled, been so long since ive been able to drive... WTB a can of motivation.... Quote Link to comment Share on other sites More sharing options...
