Z.
Everything posted by Z.
  1. Anyone? Here's a pic of the shaft I'm talking about..
  2. Hoping someone can help me here, I've just replaced the rear wheel bearings on my 280zx and now after I've torqued up the stub axle it's jammed and won't turn. When I've got the stub axle on with the nut done up firm but not torqued the thing turns fine, it's only when I torque it? Additional Note: I can't find the spacer that's suppose to go between the two wheel bearings but I don't think this is crucial because both bearings sit up against shoulder and so can't move anyway and I can't see how this would cause the thing to jam?
  3. I know there is probably something easy I'm missing but I can't seem to get the windscreen wiper linkages on my 280zx off. I'm stuck with getting the two shafts that poke through (ones for the wiper arms to connect to) to go back into the channel that runs under the windscreen where all the linkages are. There's what looks like a nut on these shafts and I've tried undoing it but it just seems to spin and not come off. Anyone familiar with how these come apart?
  4. Thanks Richard. Can't wait for these coil overs to get here! Keen to get them scrubbed up and reco them a bit. Big thank you to Jason (dat2kman) for helping me out getting these picked up and freighted to me! Absolute legend.
  5. No worries I just need your address and a number.. Could you post it on here or pm it to me? Thanks a lot!
  6. Got a mate in brissy that will pick up the coilovers. Could you pm your address and mobile and we'll sort out the details? Cheers!
  7. No worries I'll try and sort it out
  8. Would really like those coilovers.. PM sent.
  9. Z.
    71C Identification
    Thanks for the help fella's! How much did that set you back Gareth if you don't mind me asking? I had a look on his site but I couldnt see the syncro pricing only the bearing and seals
  10. Z.
    71C Identification
    just wondering if anyone on here knows how to identify the various (3 I believe) types of 71C gearboxes? I grabbed a 71c off a bloke for my manual conversion and I am halfway through rebuilding it however to order a rebuild kit I need to know exactly what car it was out of to start as there's some differences internally. Unfortunately the guy couldn't tell me what it was off originally but thinks it was an 89 silvia. Some of the online stores were mentioning the difference being the 2nd and 3rd synchro's being one or two piece? I have no idea what this means though because all synchro's I've ever seen are just a single ring. Any help would be greatly appreciated!! :/ I can post pictures if it will help
  11. Z.
    WTB Flywheel
    Cheers fellas I ended up snatching one today from a wreckers off a d21 2.4L nissan navara, which according to exedy is the same flywheel.. used this as a reference in case anyones interested http://www.fcpimport.com/products/nissan-clutch-flywheel-720-d21-pathfinder-280zx-280z-12310-n4256 Measured up to be right so let's hope it works! I got in touch with Pauly but he has the 225mm flywheel. I'm probably mistaken but I was under the impression all 280zx 2+2's had the 240mm flywheel when I posted (so I didn't specify that's what I needed) That's alright mate I do that a bit too haha. All good thanks anyway!
  12. Z.
    WTB Flywheel
    Sent msgs out.. still haven't heard anything Anybody got one kicking around at all?? Need it to get my car on the road this summer Cheers
  13. Z.
    WTB Flywheel
    Thanks Pauly I'll let you know if I get stuck Awesome thanks Sam I'll send them a msg
  14. Z.
    WTB Flywheel
    Just chasing a flywheel for a 280zx if anyone has one?
  15. Z.
    280zx interior plastics
    I would be happy with any colour. Which plastics do you have? Sorry for the late reply, been a bit busy with uni work :/
  16. do you have the interior trims that run down the front pillars?
  17. Hey Lurch I could use the r200 diff if it's still up for grabs? Also you wouldn't happen to have the square bush brackets for the rear sway bar on a 2 + 2? Thanks mate
  18. Done! I'll take them for $350 pmed
  19. Just chasing the driver and passenger side front pillar plastics if anybody has these that they're willing to part with? Also rear driver side interior trim (panel between rear quarter window and boot) If anyone has either of these could let me know that would be much appreciated. Thanks!
  20. no worries that's exactly what I'm after.. pmed
  21. I may be interested in the flywheel/clutch.. is it the 225mm or 240mm unit?
  22. Just chasing an old clutch fork and flywheel if anyone has one they can bare to part with. Would be much appreciated! Cheers
  23. Yeah definitely agree with the other boys. Replace that thermostat first >> try chemiweld (even a few bottles) >> then pull your waterpump and check that I think most likely waterpump but other 2 are easier to try first .. also just make sure to keep an eye out for milky looking coolant, sure sign of problems in the head as it leaks oil into the coolant Good luck!
  24. Well lucky ya did! Yeah I actually saw it parked at the bundoora campus near 253 one time.. I'll make sure I come have a chat next time
  25. Cheers mate.. hrmm maybe interested in the fuel rail. what are you looking for it? feel free to pm me a list of anything you're keen to get rid of/might think I could use
