KatoKid
Everything posted by KatoKid
  1. The rear floor of the LOLvo is pretty low and doesn't leave much room for suspension so shock length/stroke is an issue and there isnt much room for the ARB. The ARB can only sit behind the top of the diff housing at the highest point of the chassis so I made brackets to be welded in on each side to fix the ARB to. These are currently bolted in using the origonal shock mount bolt and will be welded later. I included some adjustment where the ARB spherical bearing bolts to the bracket to allow for providing more range of movement of the ARB arm in compression so the arm is horizontal at ride height. Also made the top shock mount and tacked them in place. With the existing diff and shock brackets we could only use a shock that would give 4" of travel which is just not enough for a drag and drive car that will tow a trailer so I made new lower shock brackets to lower the shock mount so we could use a longer shock that would give us 5" of travel. Threw everything under the car for a trial fit and very happy with set up. Enough room to clear the diff housing for the ARB in either mount position and cycles through full travel with no issues but will need to fine tune the bar lengths. Shocks are Strange double adjustable and will start with 160lb springs.
  2. Diff mocked up with black pipe for the bars for now rather than cromolly until I'm 100% happy with lengths. 2 degrees pinion nose up at ride height, it doesn't change much on bump but does on droop but not enough to be an isssue....I hope. Ride height I'm aiming for but think I will be forced to compromise due to shock length/stroke.
  3. Diff brackets done and ready for trial fit.
  4. Diff is ready to pick up so I wanted to finish the pick up points for the front of the 4 link bars on the body. We are utilising the standard Volvo body trailing arm mounts but with some adjustability built in. The lowers are alreday tacked in but the upper mounts with a captive nut in the rail and bracing from a 2.5mm pressing which looks like it would rip out on the first transbrake release! I reproduced these out of 5mm plate with some variations on where they tie in with the lower mounts. Still need to make some spacers to locate the rod ends but otherwise they are done, next will be brackets on the diff and actually making the bars.
  5. Dropped off the 9 inch to Petersen Engineering for shortening and picked up 4 Link and ARB stuff from John Lang. Looking forward to this part!
  6. Crackin morning at Highball Cars and Coffee. Anyone in Melb should go to this.
  7. Front stoppers are completed. Bit of a mish mash to get decent brakes that will fit under 15 inch wheels: Stock 240 hubs redrilled to Ford pattern 740 Turbo rotors FC RX7 calipers Dog bones from www.dvs.net.au EBC Reds
  8. Yep, been watching this and will ensure that our wagon doesnt torque the chassis over on launch as badly as this
  9. Measuring and maths to determine how much gets chopped off each side. Trimmed up the caliper brackets
  10. One of the reasons for choosing this 9 inch is that it is set up for EF/EL Falcon rear discs which have a reasonably light weight and compact PBR alloy caliper on a good sized but unvented rotor. Went to Pick a Part this morning and found a recently arrived EF that had unmolested rear brakes (most have been removed and thrown everywhere to get to the axles and ring and pinion) and got everything required. The Drum in Hat parking brake wont be used so the backing plate/caliper mount will be trimmed. The wheel bearing housings have been clocked for this application so the caliper is in the ideal position. Fits nicely inside the 15 inch wheel, just need a concentric ring machined up to locate the disc.
  11. Bump again. Were sold but freight cost killed the deal
  12. @PeterAllen these are available again if you are interested?
  13. I used to use Robco for this sort of work but he's retired now so I've been looking for a replacement and got a recommendation for these guys to redrill my Volvo hubs: https://www.yellowpages.com.au/vic/kilsyth/precision-tool-die-p-l-12937407-listing.html Really quick turnaround and very reasonably priced.
  14. We want to run same PCD wheels front and rear so had the front hubs (Volvo are 5 on 108mm) redrilled for Ford 5 on 4.5 inch (114.3mm). The Volvo wheel studs are someting like 14m diameter at the shoulder and narrow down to normal size for the threaded section so going to smaller shoulder ARP studs bought enough room to redrill and the disc goes over the top of the hub for added security. Picked up the 9 inch during the week. New housing with billet bearing housings, Strange axles and ARP studs. Will need to shorten about an inch each side but plenty of spline lenght to accomodate this.
  15. Bump and price reduction to $250
  16. It's not a show car and once the engine is in you wont be able to see the rattle can colour difference Logic would say to full back half this car but its going to be a drag and drive car with the odd cruise thrown in so close to stock/sleeper look is important. Biggest tyre that can be fitted is 235/60/15 which is 26 inches tall and it only just fits in the standard guards, a taller tyre would need the guards lengthened and a mini tub isnt worth it as there isnt much to gain without doing a full rail reaplacement. The lips on the guards are really susbstantial and just couldnt be rolled so resorted to slicing and hammering, came up really well with no external marks and with a clean up and seam seal and rattle can paint will be good. Position of the rear axle will be critical as there is only 10-15mm clearance at front and rear of guard opening and likewise the same for inner and outer guard. We are going to use the standard 4 link/panhard suspension but all of this is now junk. 9 inch has been sourced and will use cromo rod ended bars on the standard pickup points but will build some adjustatbility into it them and also the diff brackets to hopefully get sufficient separation so it 60's reasonably.
  17. haha....the dont call them Turbobricks for nothing
  18. Started with a CAD template My Cleco assistantant was on hand Got it tacked in last night and finished up this morning, Factory as.....ANDRA Tech guys wont see it
  19. Haven't been able to work on this since before Christmas so time to get stuck back in. Priority was to make as few compromises as possible with engine placement so its as low and as far back as possible but this meant it was jammed up hard against the firewall and I had to beat the fuck out of the tunnel to get it there, this was only temporary and some more serious realestate management was going to be required to allow for ease of trans removal.
  20. e-go no longer doing car parts.......I need to get a 9 inch from WA, any other suggestions?
  21. A few shots of myself and my brothers recently returned to the road Nc race car from Wandin a few of weeks ago.
